peonyu
Originally posted by: Duvie
I agree with sickbeast get the 2500+ mobile and go from there (ocing)....
If you went with the P4 go with the asus mobo and there is a very good chance you can get it to 3.5ghz on air and then it defintely would be a nice upgrade....
I had a 2500+ Barton and was lucky it could actually do 3200+ witha simple bios change....However not knowing what you do I can tell you what I use mine for the 2500@3200 speeds had tough time beating my 2.4@3.0ghz let alone even beating it at stock 2.4ghz.....
Cinebench 2003 (Raytrace rendering)
P4 3.5 = 420
P4 3.0 = 361 (16.3%)
P4 2.4 = 289 (45.3%)
3200+ = 269 (56.1%)
SuperPi 2mb (general computing)
P4 3.5 = 1:34
P4 3.0 = 1:48 (14.9%)
3200+ = 1:50 (17.0%)
P4 2.4 = 2:11 (39.3%)
TMPGenc v2.52 HT on (Mpeg2 encoding)
P4 3.5 = 2:08
P4 3.0 = 2:29 (16.4%)
P4 2.4 = 3:05 (44.5%)
3200+ = 3:16 (53.2%)
Besweet Wav to AC3 encoding
P4 3.5 = 3:43
3200+ = 4:19 (16.1%)
P4 3.0 = 4:21 (17.0%)
P4 2.4 = 5:06 (37.2%)
WMV codec 9.0
P4 3.5 = 62.563fps
P4 3.0 = 54.510fps (14.8%)
3200+ = 46.543fps (34.4%)
P4 2.4 = 44.312fps (41.1%)
Divx 5.10pro Xmpeg 4.5
P4 3.5 = 70.483fps
P4 3.0 = 61.457fps (14.7%)
3200+ = 53.623fps (31.4%)
P4 2.4 = 50.742fps (38.9%)
Again I don't know what are your uses...If you game which I don't I would think they would be too close or you would be better off getting a better vid card and leave it alone...
If you multitask then the HT of the p4 3.0 can help you there as well....
i agree.
