Here is a blurb about why the frequencies differ from the 90nm/130nm from Anandtech...
http://www.anandtech.com/cpuch...ts/showdoc.aspx?i=2242
Now to decide if the Mwave and other 3000+/3200+ 939's are 90nm or not...
Two site confirm that a 3000+ and 3200+ don't exist. So you can believe Anandtech and Overclocker.com....
or you can believe c627627.com??? [whois: Basic, Edin edilnkc@yahoo.com 5100 Foxridge Drive, Apt. 223 Mission, KS 66202]
http://www.c627627.com/AMD/Athlon64/
Also note, the body copy from Mwave maybe incorrectly cut and pasted from another spec page:
A 3200+ at 2ghz would either be a clawhammer (which both Anandtech and Overclockers say doesn't exist in 939) or a 90nm Winchester. Also take note at the bottom of every page at Mwave...
Personally, I already ordered the 3200+ 939 w/ Epox combo and a free copy of Farcry. I want a low budget path to the 939's and this looked like a good one. I don't care much if it is a 90nm or a 130nm as long as I can move to the 939 board although the 90nm would be a bonus. It should be here next Tues if you want to wait I can confirm if it is indeed 90nm. btw - price has already climbed $5 in a day on the 3200+ at Mwave.
It is interesting that AMD rates the 1.8GHz Socket 939 90nm 512k CPU as 3000+, while the Socket 754 1.8GHz 512k 130nm is rated as 2800+. Speed ratings for 939 chips are generally higher than their 754 counterparts. AMD believes that the higher performance of the Dual-Channel memory controller justifies these rating differences.
http://www.overclockers.com/tips00669/if you can find a 3000+ or 3200+ in Socket 939, you can be confident that it is the new 90nm version. Since 3500+ is produced in both 90nm and 130nm versions, you will need to ask if it is a 90nm part.
True, the webpage doesn't exactly say that they're 90nm chips, but:
1) there are no such things as 130nm socket 939 3000+ and 3200+s,
Model Number: 3200+
Frequency: 2.0GHz
Packaging: 939-pin AMD64 Technology Yes
Die Size: 144 to 193 mm²
Every effort has been made to ensure the accuracy of all information contained herein. Mwave.com makes no warranty expressed or implied with respect to accuracy of the information
