JeffreyLebowski
Once you go 64-bit you never go back.
I've been meaning to ask about this as I see it posted about regularly here. Is there a free solution available you would recommend?Originally posted by: bsobel
Originally posted by: boomerang
FWIW, I have two pieces of software that have no 64-bit driver support. DLS-2002 is used to interface with alarm panels made by DSC. No 64-bit support.
In addition, ProntoProEdit NG I use for layout, programming, etc., of my universal remote made by Philips. Again, no 64-bit support.
So, yes there are reasons to get a 32-bit OS.
Those are reasons to run a 32bit VM under that 64bit OS 😉
Originally posted by: techmanc
Well it depends on what OS your planning to run as Windows XP 64bit is imo too buggy for normal uses. It gotten much better with Windows Vista 64bit and should be best with the Windows 7 version as more good 64bit drivers will be available. That said I have run a dual boot 32bit system Vista/XP (see my sig for info) with 2gb of ram for 2 yrs and never had problem running newest games, VMWare with every OS from Window 95 and above and I multitask a lot no problem. I ran my system with 4gb of the same ram for a long time too and couldn't notice a measurable difference except want to run more than 1 VM OS like Vista with Server 2008. So in general more ram hepls but vastly overstated on it help IMO for normal desktop users and newest OS will be the best to use for 64bit OS but there maybe more compatibility with older software.
Originally posted by: VinDSL
Hrm..
I'm running "64 bit flash" - been running it for a while - runs great!
Unfortunately (for you guys) Adobe is using 'us' for Guinea Pigs... 😀
I don't understand it - don't ask...
Edit: Duh! Looks like a free download from Microsoft will do the trick.
Originally posted by: brxndxn
Windows XP 64bit is too buggy? Maybe you have incompatible hardware...
XP 64bit, imo, is the most stable of any of the Windows 'workstation' OS's.. It is fast, unencumbered by Windows Genuine Activation.. The only problem with XP 64bit is the lack of driver support.. However, if you make sure you have supported hardware, XP 64bit rocks.
XP64 makes an awesome gaming OS..
