Kabini @ 1.9GHz x 4 = 28.1 = 3.7 SpecInt/GHz/Core
Avoton @ 2.6GHz x 8 = 106 = 5.1 SpecInt/GHz/Core
AMD A57 @ 2GHz x 8 = 80 = 5 SpecInt/GHz/Core
Going to guess AMD's 80 number for the ARM SoC comes from using very fast memory, DDR4 perhaps.
So Intel wasn't lying?!? 🙂
Q15. What is the difference between a "rate" and a "speed" metric?
There are several different ways to measure computer performance. One way is to measure how fast the computer completes a single task; this is a speed measure. Another way is to measure how many tasks a computer can accomplish in a certain amount of time; this is called a throughput, capacity or rate measure.
- The SPECspeed metrics (e.g., SPECint2006) are used for comparing the ability of a computer to complete single tasks.
- The SPECrate metrics (e.g., SPECint_rate2006) measure the throughput or rate of a machine carrying out a number of tasks.
For the SPECrate metrics, multiple copies of the benchmarks are run simultaneously. Typically, the number of copies is the same as the number of CPUs on the machine, but this is not a requirement. For example, it would be perfectly acceptable to run 63 copies of the benchmarks on a 64-CPU machine (thereby leaving one CPU free to handle system overhead).
Note: a speed run which uses a parallelizing compiler to distribute one copy of a benchmark over multiple CPUs is still a speed run, and uses the SPECspeed metrics. You can identify such runs by the field "Auto Parallel".
Intel Atom processor C2750: FOR.INTEL. cpu2006.1.2.ic14.0.15aug2013 Intel Atom processor server-based platform with one processor (8-core 2.4GHz, 20W, B0-stepping), Intel® Turbo Boost Technology enabled, 16GB memory (4x 4GB DDR3-1600 UDIMM ECC), 250GB SATA 7200RPM HDD, Red Hat Enterprise Linux 6.4. Estimated Score: SPECint_rate_base2006=106
Yes, it's definitely not a direct comparison. Manufacturers have little reason to ensure complete hardware parity to make consumers less confused. Confusion leads consumers to spend more according to some studies.
Estimated ??? they havent run the benchmark ???
http://www.intel.com/content/www/us/en/benchmarks/atom/atom-microserver-specint-rate-base-2006.html
Such a surprise, isn't it?
Indeed but from the tests they published scores that are the less relevant as far as performance is a concern, looking through the details we can see that Avoton is rather weak to say the least, hence the cherry picked bench...
