- Aug 14, 2000
- 22,709
- 3,005
- 126
Oh hell no.
Instead of 50 cent PCIe connectors, we're now going to add hundreds of dollars to motherboards for connectors and circuitry because it needs to handle 600W.
Instead of a case fans dealing with the heat from PCIe connectors, we're now going to sandwich it behind the motherboard tray.
Imagine those people who constantly check their firestarter(tm) 4090 connectors. Now they'll have to remove their case side panel every day.
You can see these clowns are just trying to start a monopoly to lock their customers to their GPU / case/ mobo combos.
www.techpowerup.com
Report: ASUS to Start Production of GPUs With No External Power Connectors
We witnessed an exciting concept during the Computex 2023 show in late May. ASUS has developed a GPU without an external power connector called GC_HPWR. Unlike current solutions, this connection type doesn't require additional cables. Using the GC_HPWR means that power is being supplied directly...
