Hi,
Apparently these onboard wifi on the motherboard just doesn't work too well on
the second story of my apartment building. The router is on the first floor so the small asus white antenna keeps dropping the signal and spiking up my ping in game.
Anyone has any luck with these z77 asus wifi antennas?
My roommate takes care of the router, its in his room so i have no idea what model or make it is but my macbook pro picks up the signal just fine.
Should i just upgrade to a new pci/usb wireless card ?
I will try to answer any questions...
I am looking for any recommendations of a good solution/ wireless card.
I will appreciate the help. thank you!
