ASUS Laptop Problems [Fan Oriented]
Mireli
65
Hi there,
I bought an ASUS Gaming Laptop a year and a half ago (Christmas time), and I'm recently having problems with it. It was overheating a lot (Even with a high quality cooling fan under it).
Now, the fan is making a 'whirring' sound. It sounds like there is a piece of paper type thing it's hitting while the fan circles, I have checked and there is nothing there. So, I have no idea. It may be a bearing or something lose..
Any ideas on the problem, or the fix?
corkyg
Elite Member | Peripherals
27,370
240
Could be debris - a dead bug - a dust bunny - or a worn bearing. Fix for the first two is to blow it with compressed air, or vacuum it. For a bearing, replace it - but that is not normally a user job.
Mireli
65
It's definitely the worn bearing then. I have taken it apart and there is nothing in the way. Approximately how much would it cost to take it to a shop?
Harvey
Administrator<br>Elite Member
73
Depending on how hard it is to remove the fan, if the bearing has become stuck or the lubricant has dried, as a last ditch effort, sometimes, you can revive a fan by spraying the bearing with WD-40. If you try this, be sure to avoid spraying it on other parts.
While you're in there, see if the fan looks like a standard part that you can replace for less than you'd have to pay from sources other than Asus (or any laptop maker).
Good luck. :)
