Hey Rooster!!!
A8N-SLI (WHAT'S THE DIFFERENCE BETWEEN STANDARD AND DELUXE)...My understanding is that, it comes with ONLY extra components???
This is my system set up:
A8N-SLI (STANDARD)
ATHLON 64 3500+ (SOCKET 939 WINCHESTER)
ZALMAN CNPS7700-ALCU Ultra-Quiet CPU Cooler
OCZ EL DDR PC-3200 Platinum Revision 2 1GB (2 x 512 MB)
2 X NEC 3520A DVD-RW (FLASHED FIRMWARE USING v3.05) changed Hardware ID to NEC 3520WA DVD-RW
2 x SEAGATE BARRACUDA 7200.7 Serial ATA (200GB)
CREATIVE SOUNDBLASTER AUDIGY 2 ZS (7.1 DTS NEO EX)
LEADTEK WINFAST 6600 TH 128MB PCI EXPRESS GRAPHICS CARD
BELKIN DVI -TO-DVI CABLE
SAMSUNG SYNMASTER 17"
LOGITECH MX900 BLUETOOTH HUB, MOUSE & KEYBOARD
LOGITECH ZX2300 (2:1) SPEAKER & SUBWOOFER
ENERMAX NOISETAKER AX SERIES VERSION 2.0 600 Watt 2 (PCI-EXPRESS)
OPERATING SYSTEM WINDOWS XP PROFESSIONAL
Since purchasing the above equipment, i've never had flash the BIOS from it's original BIOS version, when shipped version 1001. Last night I'd flash it to BIOS version 1011. I did download nVidia Chipset(CK804) driver version V6.65 for Windows XP(WHQL) before flashing to BIOS version 1011. I do not have NVIDEA FIREWALL installed as i did not want it, i have also disabled the onboard sound. I'm using Norton Anti-Virus 2005, and the standard Firewall that comes with Service Pack 2 instead. Right as i was saying. At present my System can go pass the POST, and then asks how to load Windows as it's detected a change in Hardware. No matter what i select it's always rebooting itself. All i like to know is for piece of mind , which is the safest BIOS to use and (if i need to use any utilities) to clean up all traces of Previous drivers. What chipset driver should i be using, as i have downloaded the one mentioned above.
Your imput is appreciated.
Ghost
