Asus A8N-E chipset fan - How loud?
Hulk
I'm looking to build a new system around the A8N-E and have heard that the motherboard fan is pretty loud. I've also heard there is a new lower rpm fan on the newer boards.
Would I be able to hear this fan inside a Sonata II case? I do a lot of audio work so I do need it pretty quiet. Not silent but pretty quiet.
Can I replace the fan with a quieter one or even better yet a passive heatsink of some sort? Could you point me in the right direction here. This is my first AMD build.
Good question -- and you know what? I'm in the exact same boat you are! So I'll share with you and others my findings.
I purchased an A8N-E, an AMD X2 3800+ (my first AMD since their 486 series back in 1996!), and the Zalman NB-47J as a "just-in-case" purchase, since like you I had read that the chipset fan was loud (I could always return it if I didn't need it).
I built a portion of the system this morning -- no case, no ATX power header, no hard disks or CD/DVD, no video card. I completely forgot that AMD systems use DDR and not DDR2 RAM, so I thought I was screwed since all I had was DDR2 RAM. Then I found some DDR-400 RAM laying around in a box I had, but was marked bad (memory tests had failed a few times). I threw it in there just to get the system up and running. For the CPU, I chose to use the stock AMD sink + fan, as again this is my first AMD in quite a long time...
Without the Zalman, in a room with no other electronics or PCs in it, the chipset fan was the loudest thing there was. To give you an idea of the difference:
The AMD CPU fan has a "whoosh" noise, which is usually acceptable since it doesn't have a whine or a loud hum/buzz to it.
The Asus chipset fan, however, has an uncomfortable noise to it. It's obviously running at a higher RPM than it should (in my opinion), and the fact that it's enclosed in a little metal sink/container doesn't help airflow noise at all. The noise is somewhat high-pitch, and also exhibits a buzzing noise at the same time; very hard to describe. I found it to be annoying.
With both the CPU fan and the chipset fan going, the Asus fan easily trumped (noise-wise) the CPU fan. I could hear the chipset fan over the CPU fan hands down. I know my ears quite well *grin*, so I knew ahead of time that the noise was going to drive me batty once installed in a PC case...
So I chose to install the Zalman sink.
The first thing I'll tell you is, removing the Asus chipset sink+fan was not that difficult. Historically, I've run into a lot of trouble getting those little plastic prongs to fit through the excessively small motherboard mounting hole. This time, it wasn't that bad, which I was thankful for.
What I was greeted with, however, was pretty pathetic.
The Asus chipset sink is affixed to the Northbridge using some sort-of white-pink "glue pad". Since the Northbridge core actually sticks up off of the die a little bit, Asus decided to stick a black sticky-backed pad with a hole in it across the top of the Northbridge, then set the sink on top of that. My guess is that this is used to make sure that their cheap sink doesn't touch some of the exposed resistors on the actual Northbridge.
To make matters worse, the thermal paste was applied *horribly*. It was all over the place, including the backside of the black pad (yes, on the glue!). Part-of the white-pink "glue pad" was also attached to the Northbridge, mixed with thermal compound. The end result was a gigantic mess.
Needless to say, I consider all of this incredibly sub-par quality, even from Asus. There are much more effective ways to do what they're doing. For starters, Asus, please stop using GLUE-BASED pads on your sinks. There's no reason for this, since the sink is already attached to the mainboard using springed tension clips.
So how did I clean it?
I used Q-tips and 99% Isopropyl alcohol. It took me about 15 minutes and lots of Q-tips to clean the top of the Northbridge (just the part that sticks out of the die where the glue pad was attached! DO NOT clean the green portion of the Northbridge!), and I was finally greeted with the nVidia NF4 Ultra silkscreen text.
Assembling the Zalman sink wasn't that hard. But, I'll give you some tips to make your life easier:
DO NOT install the black plastic spring tension clips through the holes in the little metal "arms" like the instructions say: at least not initially! Do it once you've found the perfect positioning for the metal "arms", and screw them down nice and tight! Getting those little black tension clips out of the holes in the "arms" is a real pain, especially when you need to flip the "arms" over. Hard to explain via text, but if you buy the sink, you'll know exactly what I mean when you see it.
Also, you DO NOT need very much heatsink compound. Zalman gives you quite a small bottle of it, but you only need about 1/100th of what's in that bottle. Keep that in mind. Don't make a mess! 🙂
I find the Zalman sink construction to be pretty shoddy as well, just for the record. Using nuts and screws that *slide into the sink* via grooves? Ghetto. Zalman, please come up with something that's pre-assembled and still user-adjustable and doesn't involve nuts+screws which are as small as those used in a set of spectacles.
The remaining question you have is: what about heat? How hot does the passive heatsink get?
It gets hot. I can hold it with my fingers for awhile, but compared to the Asus sink+fan, yes, it's definitely much hotter.
But remember: my system isn't running an OS, and it's probably sitting there barely POST-ing (since it lacks a video card!). It's safe to say that in a long-term gaming session, the Zalman sink is going to practically melt. Am I worried? Yes. So...
With that said, I want to know if someone knows of a miniature fan that can be attached (somehow) to the NB-47J, and powered off of a standard 3-pin fan header on the motherboard?
Such a fan would REALLY help out with this sink when used on the NF4 Ultra Northbridge. The fan DOES NOT need to run at higher than (at max) 1400rpm. All it'd be used for is to cool the sink down a little bit.
Hope this helps you out, Hulk!
You know Corsair has lifetime warranty? If you have a bad stick, just RMA it.
A follow-up on my Zalman installation:
I cannot recommend the Zalman NB-47J as a (keyword) decent method of NF4 Ultra chipset cooling.
I have had the above system powered on and doing absolutely nothing for about 10 hours now, and the sink continues to get hotter and hotter. It's now to the point where I cannot hold it or keep my fingers on it without inducing pain. Also, I sniffed around the sink (to see if there was anything I should be concerned about), and I did encounter a very faint electrical burning smell. It was minor, but enough to make me wonder what sort-of condition my A8N-E is now in...
Therefore, my opinion is that passive cooling for the NF4 Ultra cannot be achieved unless you have a 40x40mm fan mounted near or on top of the NB-47J (I do not think this is possible to do, as the actual top surface area on the NB-47J is more like 32x28mm -- plus, if you use a 40x40mm fan, you're going to end up with something that runs between 4000-8000rpm. Yeah, that sounds nice and quiet! Not...), OR, you have some sort-of case fan (possibly a PCI card that has fans on it) blowing constantly across the NB-47J.
Those of you who do use the NB-47J and have had good experiences, I salute you. However, after reading other forums, I've found people reporting that their NB-47J runs between 45-65C even while idling. I cannot accept these kinds-of temperatures under any circumstance, as they are downright outrageous. Computing these days has gotten *way* too hot, for speed we really do not need...
Anyways, one of the forums I found DID offer an alternative cooling solution for the A8N-SLI, whose chipset fan is compatible with the A8N-E. The manufacturer of this solution is Swiftech, and the product is the Swiftech MCX159-CU.
The MCX159-CU involves a very tall (but slender in width and length) copper sink and a 40x20mm Sunon fan. They did not provide RPM statistics for the fan, but do claim the noise emission comes in at 18dBA, which is amazing (I just got done looking through 8 or 9 different fan manufacturers' websites, and all their 40x40mm fans run between 3500-8000rpm and emit between 23dBA and 30dBA).
The product appears to cost around US$35 (compared to US$5-10 for the Zalman NB-47J), which is quite a bit more than most will be willing to spend. However, I recommend people think twice about arguing the price issue; the last thing you want is a fried Northbridge...
I will be purchasing a MCX159-CU, as it looks to be a really good solution. Since I have absolutely no interest in the A8N-SLI or SLI rendering, I believe the the MCX159-CU will be the perfect solution for me. It'll probably annoy the hell out of me when working inside of the case, but decent cooling + silence is better than an annoying fan (Asus) and a passive heatsink that obviously can't stand the heat (Zalman).
For those who want reviews of the MCX159-CU:
http://www.cluboc.net/reviews/heatsinks/swiftech/mcx159-cu/
http://www.techzine.nl/extreviews/6694
Beware of the review on techPowerUp!, as the statistics they show for the fan and the like do not match with what Swiftech released (tPU claims 26dBA, while everyone else claims 18dBA).
Also, CoolerGuys seems to be selling this product with and without the fan, which makes absolutely no sense. Additionally, they claim that the model with the fan uses a "Spire" fan. Buyer beware...
This is totally off-topic, but I'll reply, since I like to distribute facts the public should know...
I refer to this RAM as "bad" because its been tested in two different P4 systems using memtest86 and has come back with memory timings issues (usually within the first 30-40 seconds). For what it's worth, I DO NOT adjust memory timings in the BIOS; I rely solely on the SPD/EPROM, and I always have. I do not overclock (any part of my systems), nor have I ever.
Corsair has begun sticking disclaimers all over their site, ditto with their PDFs, stating that they "reserve the right to change the SPD/EPROM data on their RAM whenever they feel like it". They also reserve the right NOT to change the model number or RAM revision number (the absurd "v2.1" and the like on the shiny silver stickers).
I got bit by this when buying 1GB (2x512MB) sticks from them, then buying the exact same product about a year later, only to find they were completely incompatible with one another and the system would not POST. Ultimately I found that the newer sticks they sold me were either 1) bad or 2) had memory timing issues (I rely solely on whats in the SPD/EPROM; I do not overclock or hand-adjust memory timings).
I posted on their forum, and their primary RAM dude (whatever his name was... RAMGuy or something like that, heh) came back saying that Corsair reserved the right to change SPD/EPROM data whenever they wanted -- but if customers had compatibility issues, they agreed at the consumers' expense (i.e. shipping and RMA turnaround time) to replace the RAM with a version that's the same revision/version as their other sticks.
I went ahead and did this, and Corsair sent me back the same RAM revision that I had sent them (but the modules were obviously new, so they didn't just send me back the same *physical* modules). These exhibited the same problem as the previous. I complained on the forum -- again -- and they said "Oh, we're sorry, please send them back to us again and go through the shipping order + RMA turnaround time, blah blah blah and we'll get it right this time."
No thanks.
Since then, I've read a good 10, maybe even 15 threads on their forum from other customers running into the same problem; Corsair stands by their right to change SPD timings however they see fit, not caring about compatibility.
Corsair is a crap shoot -- and that's why I no longer purchase nor recommend their RAM. At least with Crucial, you're guaranteed the same product every time, and the same SPD/EPROM timings every time. Of course, Crucial's "Ballistix" RAM is hilarious, and I won't recommend that either (overpriced + total fluff); but their standard stuff is flawless.
Corsair could solve this entire problem by simply adjusting the model number/name of the RAM itself. C3200A, C3200B, etc... The version labels they print on the RAM mean absolutely nothing.
I have an A8N-E too. I had the first-gen fan and it certainly was an annoyance. That's what I get for being an early adopter 😉 but I knew about the issue going in.
I tried passive cooling too. Same result as koitsu, I was not pleased at how hot the passive heatsink was getting. The eventual solution was this: Swiftech MCX-159CU. Actually I have the older MCX-159A with aluminum pins. If you want to get the right thing the first time, people, then get this. Extremely quiet, fits the A8N-E well, and the fasten-down mechanism is easy to deal with.
Granted, for what that costs, you'd be halfway to the price of upgrading to an Asus A8N-SLI Premium with full-passive heatpipe cooling 😱
Thanks for these very complete comments. I read your posts twice and don't see that you have a Revision 2.0 board.
Maybe you have written it and I don't see it 😱
Maybe you have Rev 2.0 board but didn't write it
Maybe you have Rev 1 board which explains the noisy chipset fan.
Please confirm which board revision you have.
EDIT: In the second of your pics above, is it "Rev 1 xx" I can barely makeout on the board, just below the A8N-E name?
If so, when did you buy that board? I would have thought that all Rev 1 boards would have been out of the retail channel by now.
Thanks koitsu.
So it is Rev 2.0. Really disappointing news. The MCX159-CU link shows that a better, quieter solution is possible, but one has to accept voiding the warranty in implementing it.
The Evercool VC-RE fan runs at 5000rpm; how can that be even *remotely* quiet? 2500rpm and below is quiet.
http://www.bigbruin.com/html/evercool-vcre.htm
I'm also not too sure the VC-RE will mount/fit on the A8N-E. The mainboard mounting holes are in a very specific position, and there are components quite close to the NF4U chipset itself (meaning, the VC-RE may require modification via a Dremel or the like).
If you find the VC-RE to be to your liking, post your experiences here (positive or negative) and let everyone know. One thing is for sure: none of us like the stock fan on the Asus boards. 🙂
Originally posted by: BernardP
Thanks koitsu.
I'm not sure where the proof is regarding the Rev 2.00 boards having quieter fans than the Rev 1.00 boards. I've yet to find any actual audio samplings of the fans used on both revisions, so I can't tell you if I'm just being anal about the 2.00 fan or if there really _is_ a "loud fan" on the 2.00. Know what I'm saying? I have no frame of reference.
All I can tell you is that the fan easily trumps the stock AMD CPU fan (I'm amazed at how quiet it is, too. Beats the pants off of the stock Intel fans, even today).
If anything, the noise the Asus fan emits reminds me of present-day video cards -- which are still by far too loud.
Well I was posting from personal experience. Ive never owned one. I just know many people seem to like to use it on their DFI lanparty boards(its compatible with those).
FYI guys, Revision 2.00 motherboards can still have the extra-bad fan. The board's PCB revision has to do with the PCB, not the fan.
In a Sonata setup, the front "middle" fan could be blowing right over the Zalman NB heatsink giving it some airflow. That said, I also have a Zalman NB heatsink on my A8N-E and while it is a bit warm to the touch I haven't had any problems with stability. Voiding the warranty to make this change is a downer, but maybe in the future you'll keep this in mind and buy the versions with heatpipes 😉
Well i have a Rev2 board ,and the fan was screamy loud from the beginning. A month or so running, its noises changed in tone from stutter - scream - hiss whatever. Its running like that almost half a year now doing those hickups sometimes ,but is still running. Its keeping a constant 5100ish RPM thou.
THanks for the 2nd pic koitsu, i had concerns a sink would not fit with my graphics card at first.
