mechBgon
The Deluxe has the MCP-T southbridge and does have the Soundstorm setup. From Evan's shootout...
So it sounds like Asus just shuffled the deck a little differently and the default drivers from nVidia will look in the wrong place and not see the hardware. This is a bit of an annoyance, since Asus is not very timely in adopting updated drivers (their A7V333 page still has VIA's 4.37 4-in-1's, for instance, and we're up to 4.45's now). Nothing's perfect, I guess...
Random comment: one of the Soundstorm prerequisites is evidently that there's some way to hook up 5.1 output, and Asus has an RCA-style outlet in the rear panel, as you know. EPoX has everything but this with their 8RDA+, so they don't get an official Soundstorm stamp of approval but the module can be purchased separately (at a hefty $35US, ouch). Hopefully the 8RDA2+ will address that.
Lastly, we need to note that you can install the v. 2.00 drivers on all of the nForce2 motherboards tested here today except for the Chaintech 7NJS and ASUS A7N8X Deluxe. In the 7NJS's case, you can install the v. 2.00 drivers, but the audio portion of the install will be skipped entirely, meaning your sound won't be operational, but the rest of the v. 2.00 driver package will be successful. This is due to the fact that Chaintech uses C-Media's CMI8738 instead of the nForce2 APU.
In the A7N8X's case, you CAN install the v. 2.00 drivers, but the audio portion of the install will fail (i.e. it will be skipped entirely) because ASUS decided to assign different device ID's/product codes to the SoundStorm audio. However, the A7N8X's SoundStorm is still the same as any other SoundStorm audio found on any other nForce2 motherboard. We suggest you install the SoundStorm drivers that come with the A7N8X motherboard for best functionality.
