CompKidRRO
Computer Specs
Motherboard - ASUS A7N266-VM
HD - Western Digital 7200RPM 40 GIG
CPU - Athlon XP1600+ (Not OC)
OS - Windows 98 SE
Display Adapter - NVIDIA GeForce2 Intigrated GPU
Anti Virus - Norton 2002 Works Professional
This is what has been happening.
I built the computer around a week ago.
Formated HD.
Installed OS.
Installed Anti Virus.
Installed and updated drivers from NVidia Website.
Downloaded Motorcross Madness 2 (MCM2) and Midtown Madness2 (MM2) Trial Versions.
Installed installed MCM2 and MM2.
Tried MCM2 a few times and the Video went way too fast (The sound was normal).
Tried MM2 a few time and the Video sometimes went normal and sometimes fast (The sound was normal).
Also the left mouse button was not working correctly (Had to double click just right).
Turned computer off.
Booted computer on.
Only could get to the desktop with no Icons or start button.
Rebooted, same thing happened.
Rebooted, got blue screen (somthing to do with the OS).
Rebooted, right after Win 98 Logo, all I got was a black screen.
Quick format HD.
Installed same OS.
Installed and updated drivers from Nvidia website.
Downloaded and installed MCM2, MM2.
MCM2 still always fast.
MM2 sometimes fast.
Still having problems with the mouse.
I tried MCM2 again and got a blue screen while playing.
It said "A fatal exception OE ocurred at 0028:05940016. The current application will now be terminated" Then there was press any key to continueor CTRL+ALT+DEL to restart computer.
I clicked "Any Key" then the computer showed all the bright colors of the rainbow probably more and froze.
I turned the computer off.
Now what should I do?????????
OS - Windows 98 SE
Formated HD.
Installed OS.
Booted computer on.
Quick format HD.
Installed same OS.
MM2 sometimes fast.
