- Oct 3, 2015
- 5
- 0
- 0
Hello everyone. So I'm going to explain this to the best of my ability, if I don't explain something right, just let me know and I'll try to reexplain it.
I built a new computer yesterday, and it booted up just fine, installed windows and started playing games at max settings, it was awesome.
This MORNING I woke up and decided to organize the cables a little better to make it look more clean. So I disconnected some of the fan cables and the power cables one by one, each at a time, and routed it to go behind case.
I plug everything back in and I went to turn the computer on, and some of the fans were not spinning or lit up, so I checked and realize that I plugged them into the wrong spot. I plugged them into the correct spot and they turned on and started spinning, but it was at this moment I realized my monitor is not displaying anything, no bios or anything.
I'm still learning, but apparently this is called a "No Post"?
Every time I turn the computer on, all the fans and led turn on, even the LAN port blinks, and some of the USB devices get powered(except the keyboard), but the Monitor never displays anything. I'm also not hearing any beeping from the Mobo...
I tried many things to fix this, I tried using only 1 ram stick, and I tried each slot at a time. I even tried using NO ram to see if I hear a repetitive beaping, and not a single beep or noise.
I assumed that the Mobo is faulty so I ordered a new one and it should be here in a couple days. Any suggestions or opinions? I thought that if a Mobo was dead it would not power fans and stuff? Is it possible that just a part of the Mobo is faulty?
Any thoughts guys would TRULY be appreciated. And let me know if you need me to give any more detail on anything. Thank you so much guys.
