- Feb 10, 2011
- 135
- 5
- 91
TLDR: My wireless mouse does not work on some of my USB3 ports when my Z87 build is under load. Why?
On my Z87E-ITX everytime there is CPU activity 4 of my 6 USB3 ports have really bad 2.4GHz interference that effects my wireless mouse dongle. Is this normal for the Intel Z87 platform?
The interference is so bad that if Prime95 is running I cannot move my mouse at all. Yet if I use the tiny USB extension stick that came with my wireless dongle everything works great (even with Prime).
Note: The 2.4GHz noise issues when using a caused by using high throughput USB3 is pretty well documented but in my case the only thing that is running off the USB3 bus is my mouse.
