ASRock Extreme6 build
Chipfiref
Someone PMed me about clearance of the Noctua cooler and the PCI slots. Sorry whoever sent it, not sure what happened to the PM sent about August 5, but I just saw it today now I can't find it...
So here are some pics and inof on my ASRock Extreme6 build...
Coolermaster Cosmos 1000 case circa 2007
Code:
Soundproof materials applied to build a quiet environment
Sound barrier design reduces vibration for silent operation
Dual bottom air intakes to enhance air flow and reduce system noise
Six aluminum detachable HDD modules with ventilation holes for optimizing cooling performance
Side removable VGA cooling tunnel to advance thermal airflow
Patented finger pressing buttons for quickly maintaining
Tool-free design for opening side panel conveniently
Separate HDD modules make it easy to organize cable direction
Cable management system for better cable routing and neatness
http://www.coolermaster-usa.com/product.php?product_id=2700
ASRock Extreme6 Z87
Code:
A-Style : Home Cloud, Purity Sound™, HDMI-In
Supports 4th Gen Intel® Core™ i7 / i5 / i3 / Xeon® / Pentium® / Celeron® in LGA1150 Package
Premium Gold Capacitor Design, Digi Power, 12 Power Phase Design, Dual-Stack MOSFET
Supports Dual Channel DDR3 2933+(OC)
3 x PCIe 3.0 x16, 1 x PCIe 2.0 x1, 1 x mini-PCIe
Supports AMD Quad CrossFireX, 3-Way CrossFireX, CrossFireX
Supports NVIDIA® Quad SLI and SLI
Multi VGA Output Options : DVI-I, HDMI, DisplayPort
Intel® Dual Gigabit LAN with Teaming
7.1 CH HD Audio with Content Protection (Realtek ALC1150 Audio Codec), Supports DTS Connect
10 x SATA3, 1 x eSATA, 8 x USB 3.0, 7 x USB 2.0
1 x Front USB 3.0 Panel with 2.5" HDD/SSD Rack, 1 x Rear USB 3.0 Bracket
Supports A-Tuning, XFast 555, Easy Driver Installer, FAN-Tastic Tuning, USB Key
Corsair HX-750W power supply
http://www.hardwaresecrets.com/article/775
i7-4770K CPU
Noctua NH-U14S CPU Cooler
http://www.tomshardware.com/reviews/...ll,3554-5.html
<--- not my mobo or memory
G.SKILL Sniper Gaming Series 32GB 1600
Samsung 840Pro SSD 500GB
Plextor DVD
This build is in progress as I have a full time job and other activities - benchmarking and overclocking continue.
Here is a pic of the Noctua in relation to the PCI slots - a card in the Mini PCIe slot could bump up against the Noctua if it was too long
Notice that there is JUST ENOUGH room to mount the cooler next to the Memory. Crazy heat spreaders may be a problem but this G.Skill Sniper memory is OK.
That sounds like a really nice build. Let us know how things go.
I'm actually waiting on UPS to drop off the parts to my new build for an ESXi server with the same MB:
Fractal Define R4
ASRock Extreme6 Z87
i5-4670 (non-K for VT-d)
G.SKILL Ripjaws X Series 32GB
SeaSonic SSR-650RM 650W
PERC6i w/BBU (raid controller)
(5) WD Red 2TB (RAID10 + HS)
Intel PRO/1000 Pt Dual Port Server Adapter
I'm going to use the stock Intel cooler until I figure out what I want to do. That memory has obnoxiously large heat spreaders which I should have considered beforehand. Thankfully, I'm not looking to OC or anything so an inexpensive quiet CPU cooler shouldn't be hard to find.
Eventually I'll throw in an SSD if needed for more IOPS
Needless to say, I have my weekend planned. (Hurry up UPS!)
Just for playing around with ESXi at home - nice 🙂
This box will theoretically be used for a server also - Windows 2012/Linux/Win 7 is the plan. I have plenty of disk space in my case and this MB gives us 6 SATA III from the Intel chipset (plus 4 more from the ASRock chip) and dual Intel Gigabyte NICs. Not too shabby!
