igor_kavinski
- Jul 27, 2020
- 28,173
- 19,204
- 146
WHY does it say ASUS???The card comes with the latest bios. Even newer than on the ASROCK website. No need to update.
SO it already has the updated FASTER bios on then ?Here are the specs on the bios from techpower up. https://www.techpowerup.com/vgabios/253337/253337
Bios build date 9-15-2021. The memory in my card is Samsung as you can see in GPU-Z. According to the bios internals, Samsung DDR6 goes to 2250mhz while the Micron and Hynix modules max out at 2000mhz.
Today's conspiracy theory - ASRock isn't as independent from Asus as we have been told...WHY does it say ASUS???
It came in a brown cardboard box. The box is probably smaller than the retail box but the foam padding is custom fit for the box. It has an Asrock quick install guide book inside. The outside of the box has Asrock sticker with a part number, model number and serial number just like on a graphics card box or motherboard box. Bar codes as well.I tried to install the GPU in the potato, and while it detects fine and boots, my drive disappeared. I think the GPU is touching something on the bottom edge near the motherboard. Some electrical tape might solve it. Reinstalled old GPU and the drive is ok.
Hans did your GPU come in a plain cardboard box or retail box?
Ok thanks. My box is the same as yours. I might try to install again tomorrow to check GPU-ZIt came in a brown cardboard box. The box is probably smaller than the retail box but the foam padding is custom fit for the box. It has an Asrock quick install guide book inside. The outside of the box has Asrock sticker with a part number, model number and serial number just like on a graphics card box or motherboard box. Bar codes as well.
Please list your potato PC specs.I tried to install the GPU two more times and the potato doesn't get along with it. Don't think it is the GPU but rather my potato is too vintage. I'll wait until my new build to try again.
Intel i3 530 (stock)Please list your potato PC specs.
Here is a problem some people may face. They are not all 5600XT versions. I ordered a 2nd one and got a 5600 oem.
AMD Radeon RX 5600 OEM Specs
AMD Navi 10, 1560 MHz, 2048 Cores, 128 TMUs, 64 ROPs, 6144 MB GDDR6, 1500 MHz, 192 bitwww.techpowerup.com
What is weird, the memory and the core clock are XT but it shows 2048 unified shaders instead of 2304 and ROP TMU is 64.128 instead of 64/144 on the XT bios. The bios version is identical to my first one. The AMD adrenaline software calls my 1st card a 5600XT and the 2nd one is 5600 OEM. GPU-Z shows 5600 OEM. But, the core clock and GDDR6 Samsung Memory is the same as XT version.
If you ordered one of these cards, use GPU-z to verify what you have.
It is still a great deal. If it had 8gb memory. It would be an even better deal.
