CharlesMcKinney
- Aug 15, 2004
- 99
- 0
- 0
Alright, can someone explain the whole RAM divider thing? And yes, professor, it is indeed a 9x CPU. Thanks for the replies!
Originally posted by: quandasar
i just noticed that a new bios has been released , with this "Add one item "AGP P2P Deep Fifo" in BIOS setting."
what excatly is this, any reason to upgrate to the 1.60 bios ?
Edit: To be more clear, the RAM speeds listed are dividers out of the default speed of 200MHz...setting it to 200MHz won't keep your RAM at 200MHz, but instead will lock it to whatever your HTT speed is...similarly, setting the RAM speed to 166MHz will lock your RAM to 5/6 (166/200) of your HTT frequency...
Originally posted by: Neptune3000
get teh DFI
I wish I did. This board is not worth the hassle.
Just to explain this a bit further, the way to calculate actual RAM speed is this:Originally posted by: professor1942
With a multiplier of 10, the ratio will be exactly 5/6 but if it's something like 9 or 11, it is a bit different. The CPU can only use a whole number to 'divide' by to determine RAM speed, and it will always use the number that gives it the closest speed _not greater than the selected speed_: for example, my 3700+ Sandie is 11x200 at stock, and if I set mem speed to DDR333, it will actually get set to DDR314 because the closest whole number to divide by
is 14, (ie. 2200 / 14 = 157, it won't use 13 because that will exceed the spec of 166.67)...
make sense? It puzzled me a bit at first.
About your CPU voltage issue...2.7GHz is a very nice overclock for a 3700+, and it doesn't surprise me that it's not entirely stable at 1.45V - that voltage isn't very high (and isn't the default already 1.40 for that chip?). I did the voltmod myself and it helped quite a bit - anything over about 2.4GHz was a no go on my Opty 170 at 1.4V, but now 2.6GHz is rock stable and I've seen it as high as 2.75 while playing with it (soon I'm going to go back and try to make 2.7+ a permanent overclock, just haven't had the time to mess with it lately). I do wish this board weren't quite so voltage-limited by default, but at least it is rather easily moddable (to 1.55V anyway, which is sufficient for most non-extreme overclocking) - and you can't expect to have it all in a $70 board.![]()
(delayed response)
Yeah the default is 1.4v, and setting it to 1.45 actually gives it 1.46-1.47... I'm stable up to 2.63 Ghz which is still pretty nice for it being stock cooled (an extra 430 Mhz)...
Common sense tells me it's not worth bothering with the volt mod to get it up to the 2.7-2.8 range, yet those little voices in my head keep pestering me to do it...![]()
Originally posted by: hclarkjr
ok guys, thinking of buying a asrock motherboard to run a A64 3800 single core chip on. will be using things listed in signature below. can you forsee any problems for me? with the OCZ 520 watt power supply? reason i ask is that i recently had problems setting up an X2 system with an ABIT AV8 motherboard because my power supply was causing an error during boot up. what do you think?
question, will a A64 3700+ San diego chip work on it if i buy it from newegg regardless of what bios it comes with? not sure what bios version they are shipping with from newegg
Originally posted by: trevor0323
Seriously What Bios is best for overclocking. I had 1.5 and it has like 174 for max HTT I then put on OCW Beta 2 because I heard it can go higher then 174. Anyways its buggy all over and when I put the HTT to say 180 it still reads as at 1.8ghz so I dont know whats up. I tried like 176htt and still the same problems occur. Also This bios sometimes crashes windows before even loading into it.
What bios are you guys running, I seriously rather run 1.5 which allowed me to 2.4ghz and no booting problems the OCW 2 which I still cant figure out why it wont OC and causes my PC to crash before even loading win
Originally posted by: MrX8503
I was pretty much set in buying the Epox ultra nf4 mobo for my x2 3800 in hopes of overclocking, but this asrock has caught my attention, especially the M2 upgrade. This feature is priceless in my opinion, it would allow me to upgrade without a new mobo.
from reading the posts, to my understanding, i would be able to overclock my x2 to 2.4 rather easily? with 1.5 bios. My main goal is to get to 2.4ghz anyway so even if asrock limits me to just this i would still be happy.
now the question is, i was reading the quick and dirty a64 overclock and said some mobos doesnt come with locks. Does this mobo have locks?
EDIT:
i will also be using this ram
http://www.newegg.com/Product/Product.asp?Item=N82E16820231047
sweet this makes up my mind pretty much
cheap mobo
2.4ghz oc
and futre m2
and AGP
edit:should i go with 1.5 or 1.6bios?
