Originally posted by: Tyhr
Ok, I'm a crazy odd one, and I haven't been able to find an answer.
I read somewhere that it is possible to hook up 4 monitors to this motherboard at the same time (2 to the AGP card and 2 to the PCI-e card).
Now not considering the performance hit in doing so, and not playing games, but does anyone know if the 4 monitors are hooked up - they will be unique (desktop extends to all of them), or are 2 monitor's mirrored?
I just happen to have some extra monitors lying around, and I was thinking this geek factor may impress some of my non-female friends, LoL.
Video editing in 2 windows, surf on the 3rd, and IM on the 4th?
Originally posted by: nzimmers
Well seems my Asrock -VSTA is DOA =(
just got it via fedex - popped in the conroe, and some DDR ram and an AGP video card - when I plugged in the power the CPU fan started but no post beep - strage, so I swapped ot the ram, same thing - no post or display
reseated the CPU twice - nothing
shorted the cmos jumpers and now won't even spin the CPU fan
went to Best Buy - picked up a top of the line Antec - No joy
SHOOOOTTT!!!
there's a few more things I can try - but looks like I will have to RMA
Bios chip sticker has ver 1.1 on it
anyone have suggestions before I RMA it??
Originally posted by: anandus
Is it an AGP or a PCIe card?
If it's a PCIe-card, better check here to see if it's supported?
(Although that list is far from complete and if your card isn't mentioned it doesn't have to mean anything at all)
Originally posted by: Nighthawk
Yesterday i ran into trouble with the Asrock: winxp freezes while loading:-(
When I uninstall the catalyst 6.7 driver, it boots up again. I removed all extension cards, loaded bios defaults, reinstalled winXP, same behaviour: only boots up when catalyst is not installed.
The ATI cards works in another PC... so i think the asrock is the cause. The strange thing is: a day earlier, the same system worked completly stable.
Tried both settings, made no difference.did you set the motherboard bios to boot with AGP enabled? otherwise it may be trying to boot from the pci-e slot first.
I did not change any driver settings after reinstalling windows.Set it to default and if it?s on overdrive.
