ASPI for WinXP - need WINASPI.DLL and WOWPOST.EXE ??
daveqb
480
www.dward.us
i installed the latest aspi files 4.711,
but now aspi cheaker returns htis
WINASPI32.DLL 4.711
WINASPI.DLL N/A
ASPI32.DLL 4.711
WOWPOST.EXE N/A
ASPI is not properly installed. One or more components
have been replaced with older versions of the software.
the adaptec logo is red, (means not rightly set ??)
i downloaded the files from adaptec,
am i right to run with this ?? (do alot of DVD rips and CD burning)
solutions, examples of other systems etc ??
thanx
:D
edit: or should i have this instead ??
older drivers, but all the same atleast
PliotronX
8,883
107
Windows XP doesn't use Wowpost.exe nor Winaspi.dll. It will display a warning that components are missing, but those two files aren't needed.
daveqb
480
www.dward.us
yeah i downloaded forceaspi but was reluctant to install as i saw from a screenshot they are the old 4.60 rather then the new 4.71
i figured the new ones would be better, but the incompletness baffled me
would using the 4.60 apsi drivers, BUT with all of them be better ??
