[Ashraf] 10nm "Lakefield" SoC with Intel big + little cores
Page 13 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
krumme
5,956
1,596
Ok now we know why this hasnt been done before.
Something just looks better in theory and on paper, and takes years to mature, if at all.
Still likes the idea though...lol
DrMrLordX
22,903
12,974
Maybe Lakefield will be better at balancing multiple processes than trying to commit all cores to one multithreaded process.
Reactions: mastercoin
piokos
554
206
86
First benchmarks. It does manage to beat the 8cx in the Galaxy Book S in the browser tests but only barely in most of them.
Frequency is pretty low on the R15 run, only getting 2.4 Ghz on the single core test and 1.9 on the multi core test. That gives a score of 255 on the MT test which is pretty low and is about what an n5000 gives anyway.
These benchmarks apparently haven't used the big core even in single-thread tests. It's essentially a 4-core Tremont and the results are pretty good seen as such.
And we shouldn't be surprised because heterogenous core global scheduling will be added in Windows 10X.
This preproduction Samsung Book S probably uses normal Windows.
Author should have included W10 version (essential) and power consumption per core though the whole test (nice bonus), which would make this obvious. Pretty lame article.
Notebookcheck remains the best source for laptop reviews, because the test team is really solid.
And the simple fact is: the guy writing articles (Osthoff) just isn't technical enough to properly cover components.
piokos
554
206
86
Geekbench 5
Lakefield (Sunny Cove x1 + Atom tremont x4)
SC 843 | MC 1631
This makes a lot more sense - as expected - matching a 1035G4 in slim devices (Surface Pro etc).
Also MC/SC~=2, which was a design choice Intel mentioned a lot.
So someone knows how to benchmark Lakefield properly (or got a better Windows version ;))
jpiniero
16,810
7,254
Appears to be bouncing between the big and small clusters on the R15 single core test. Seems to be working more properly on the browser tests.
piokos
554
206
86
Well, putting aside the lacking article and the poorly functioning benchmark, Tremont looks really good.
These 4 cores are expected to pull 2-3W under load. They match 6-10W Pentium/Celerons (admittedly, pretty old ones).
I really wanted to buy a NUC with N5000 or J4105. I just lost all interest.
mikk
4,296
2,382
@Antey
J5005 makes a more-interesting point of comparison.
It's a desktop chip and can use more power.
Cinebench clearly didn't use the big core in the singlethread test. The question is why is this, could it be a software issue which possibly could be fixed.
DrMrLordX
22,903
12,974
True! However, there are some GB5 results for it that run at nearly-fixed clocks close to its turbo limits. It's very easy to get data from those runs for some kind of half-arsed IPC comparison.
mikk
4,296
2,382
From a Notebookcheck forum writer:
These results are meaningless without the Windows version.
Scheduling for Lakefield will be added in W10X.
If this uses existing W10, you're essentially testing a 4-core Atom.
It sounds plausible and it's a huge mistake from Notebookcheck to ignore the windows version, also the driver infos are missing.
jpiniero
16,810
7,254
Obviously it's not going to be 10X. It's not available yet.
The Sunny Cove core is definitely being used, it's just buggy and not the way you would expect. You can see why MS decided to wait.
coercitiv
7,355
17,425
Check the name of that writer.
The Samsung Galaxy Book S is an ultra-thin laptop that will be sold with Win 10 Home/Pro.
We still don't have confirmation that the Galaxy S that Notebookcheck got their hands on is a final retail unit with mature scheduler, but a forum poster repeating his idea of truth as fact is not the best way to get to the bottom of this.
IntelUser2000
8,686
3,787
One of the articles about the Lenovo X1 Fold said 10X will have optimizations for it. I assumed battery life but surely scheduler is another?
I was worried scheduling will be difficult. If you look at NBC's Task Scheduler screenshot, there's one core that's not working, and I bet that's Sunny Cove.
I don't know how you came to that conclusion. The MT performance, therefore Tremont performance is no better than Goldmont Plus. They are pretty much at the same TDP level.
Reactions: spursindonesia
bullzz
405
23
I didnt expect intel low power graphics to be this close to qcomm considering they have been doing this longer than intel. it will be interesting to see what tigerlake does
Thala
1,355
653
Does not need to be added, because it works nicely on the Surface Pro X. At least it would be suprising if x86 Windows does not have all the scheduler updates from Windows ARM.
coercitiv
7,355
17,425
Yeah, I posted the CB15 MT screenshot on the previous page, aligns perfectly with your previous theory based on benchmark scores.
The ST benchmark screenshot looks equally weird though, the Tremont cluster is under some type of continuous load according to the Task Manager.
coercitiv
7,355
17,425
Notebookcheck also published a first impression article on the new Galaxy S, and the supposed strong point of Lakefield is not really there:
The Intel model uses a bit more power in almost every scenario, which is also noticeable in the battery runtime. Samsung advertises a lower runtime, and our results so far confirm that: The load test runs for almost 4 hours (without outdoor mode), 2 hours less than the ARM model. The Wi-Fi test at 150 nits is still running, but it should result in about 11-12 hours compared to more than 16 hours for the ARM model.
They are actually reviewing it, which means they believe it's a final retail unit or equivalent.
IntelUser2000
8,686
3,787
This is how it looks on my desktop i3 7100 under Cinebench R15 ST.
I tried assigning only 1 thread to it. The power usage doesn't change much. Sure it looks different in Task Manager, but my scores were nearly 10% better just letting Windows do its own thing. Even HWInfo is showing it as the load being spread over 4 cores. Does perform like a 1 core so I have to assume its just the graphics that's off. I know Windows lets threads hop between cores.
Of course that won't apply to Lakefield with a whole new paradigm.
In order to know the whole story, someone has to sit down and just analyze Cinebench. I would have HWInfo up and track power and clock numbers as I'm changing thread assignment through Task Manager. No site is going to do that though.
Yup. It's still better than the U series but seems about the same as Y. Intel talks in their presentation that enabling Sunny Cove allows 33% better performance and 17% better perf/watt under WebXPRT 3.
mikk
4,296
2,382
Notebookcheck:
Interessanterweise sehen wir bei Single-Core-Belastung maximal 2,4 GHz und bei der Verwendung von allen Kernen laufen 4 Kerne mit ~1,9 GHz und 100 % Last, während ein Kern mit knapp 10 % Last und 200-300 MHz arbeitet.
Notebookcheck says the chip only clocks up to 2.4 Ghz in Singlecore workloads and ~1.9 Ghz for 100% multithreads workloads which uses 4 cores, apparently the Tremont cores. The fifth core is idling. The sreenshot is from Cinebench, so it might look different in other applications. But it's obvious that Sunny Cove isn't working in Cinebench R15/R20 Singlethread.
Did someone notice the Cinebench R10 32 bit scores? Singlethread looks much better there, this must be Sunny Cove.
Cinebench R20 1T
i5-1030NG7 330
i5-L16G7 182
Celeron N4020 175
Cinebench R10 32 Bit 1T
i5-1030NG7 4250
i5-L16G7 4079
Celeron N4020 2184
Reactions: lightmanek
IntelUser2000
8,686
3,787
I compared using all available 8500Y and N5000 data. You just type the name of the CPU click it.
Observations-
Under browsing benchmarks its competitive and and Cinebench R10 ST(32-bit), its drastically faster than Geminilake Refresh N5030. 63% advantage tells me its running on Sunny Cove.
@mikk
8500Y outperforms the 1030NG7 only in Cinebench R10 32-bit ST. But it performs worse in newer benchmarks.
Why is Task Manager saying its at 100% load under multi-threaded loads? Is it actually running Sunny Cove or is it a misreport?
mikk
4,296
2,382
Looks like task manager load info ignores Sunny Cove in this case, we can see from the screenshot there a 4 cores fully loaded and the fith core is loaded with 10%, Notebookcheck says the fith cores runs with only 200-300 Mhz. Or possibly Sunny Cove is running but with 200-300 Mhz only?
IntelUser2000
8,686
3,787
Reviewers should take advantage of HWInfo more.
So I downclocked my CPU by approximately half, which is 1.9GHz and when I run MT Cinebench Task Manager says its at 48% utilization. HWInfo reports it correctly and says its 100%.
Reactions: Tlh97 and coercitiv
jpiniero
16,810
7,254
Problem with NBC's browser benchmarks is that they don't say the browser used. For Windows, would it be IE, Edge, Chrome, MS Chrome?
