- Jul 20, 2007
- 17
- 0
- 0
The system:
QX6850 @3.0 ghz (9x clock multiplier in bios)
Asus P5k3 deluxe
4x gb supertalent ddr3 7-7-7-18
XFX 8800 ultra
soundblaster xfi fatality (currently disabled - using mobo sound)
2x wd raptor 10k rpm 150 gb drives in raid 0
samsung 500 gb data drive
plextor dvd/rw
case-coolermaster stacker 830
psu-1100watt coolermaster(the one that came with case)
cpu cooler - thermaltake 120 ultra tower w/120mm attached case fan
The backstory:
I built this system in September, the former CPU cooler died in October, right before I left on business for a month and half. Post office lost package with the busted tuniq tower I sent back. The motherboard would sometimes say overclocking failed and it's not overclocked... every once in awhile I'd get this on boot and have to go into bios and change from auto to manual or manual to auto settings.
I had to remove mobo to change the backplate for new cpu cooler (thermaltake 120 ultra tower) and when I put it back in... nothing. my beautiful samsun 22 inch sat there doing nothing. no beeps, no anything. the fans were all running and the mobo recieving power but that was it. After fiddling with stuff... it booted in a few times but crashed alot. I updated windows vista 64, updated virus (mcaffee), updated a couple games. I was getting crashes where mouse(logitech g7)/keyboard (logitech g15) locked up. Had some issue on install/config for updates to logitech ball cam also. Now, can't get it to boot into windows at all. Was able to get to safe mode before at least on crash. Can't use vista repair. Stalls after it gets through the loading bar...
Ideas? I ran memtestx86 on my ram before and no issues. Is it possible the mobo is defective or what else would this be pointing to? I'm really sick of this cause I bought what should have been high quality components.
Recommendations on what to replace the mobo with? Also, I'm using Vista 64 oem so how is that affected if I have to replace mobo... I seem to remember the oem copies being registered to the mobo making it hard to upgrade. or was that the processor....
Thanks in advance!
Asus P5k3 deluxe
XFX 8800 ultra
plextor dvd/rw
The backstory:
Thanks in advance!
