Argh! I need help finding a toggle switch!
xbassman
I have a CCFL kit in my PC and it comes with a round rocker switch that requires a 3/4" mounting hole. that is entirely unacceptable.
I would like to find a toggle switch that I can mount on a 3.5" drive bay.
This sounds easy enough, but since I'm not an electronic engineer it is proving to be quite difficult! 🙁
I am sure Digi-Key has plenty in stock that would meet my criteria, but I am lost looking @ SPST, DPDT and other such specs.
If somebody here "in the know" could help me out I would really appreciate it!
Thanks! 🙂
Your local radio shack or other electronic parts store... SPST is likely what you want. P=Pole=1 switched circuit (usually the input). T=Throw=contact positions (usually output), S=Single, D=Double. So SPST=one circuit on or off, SPDT=one circuit connects to two different outputs on/on and sometimes has a center-off position. You do NOT want momentary contact!
.bh.
Thanks Zepper!
Got another question though....
Radio Shack's selection of DC switches is pretty limited.
Do I have to stay with switches rated for DC, or would an AC toggle switch be safe?
