Originally posted by: TheSnowman
Originally posted by: xtknight
Looks very similar to this at 0xAA: http://xtknight.atothosting.com/wolf-640x480-ps-scaling.png
Even worse than that because that was a photoshopped (higher quality) simulation.
Looks very similar to this at 2xMSAA: http://xtknight.atothosting.com/wolf-640x480-2xaa-ps-scaling.png
Again worse than that as well.
RGAA almost eliminates all those artifacts though.
It can be attributed to a bad scaler IMO. My VP930b certainly isn't too good at it either at 648x480.
Those pics look the same, you didn't have AA working in either. And why did you scale a 4:3 resolution to a 5:4 one? I can post some decent upsampled shots from 600p to 720p with and without AA if need be.
Because he is also scaling different aspect ratios.
Dell: 16:9->16:10
Samsung: 16:9->5:4
They are not the same. The second one has 2xMSAA enabled on a 7800GT. The difference was obvious when they were at the original size, but I didn't keep the original ones. It is still pretty evident if you look at the edges. The second one's lines appear fuzzy blurry while the first one's are raw and jagged.
The best thing to do is use 1:1 scaling (fixed aspect ratio). That will at least keep the aspect ratio the same and greatly improve quality on an LCD I have found.
