Are tower fans better than regular fans?
BoomerD
65,902
14,301
Space efficient maybe...but compare the air flow of a 12-15" fan against 3-4 4" fans.
13,566
I don't think one is better than the other, it's just a form factor. Just don't over pay for gimmicky things like "blade less" fans. It's a neat idea but not worth paying 100's for.
Zeze
11,395
1,188
Do they push more air or are they just more space efficient?
Fan blades are fan blades. Tower fans are probably for its form factor.
Anything medium or heavy duty, they're all squares.. probably for a reason.
purbeast0
53,543
6,368
Box fans > *
The white noise on those things can't be beat and they blow a shitload of air.
Reactions: lxskllr
Nov 17, 2019
13,229
7,851
Any medium or heavy duty fans I've seen are round.
Cyclone 45T - W. 18 Oscillating wall mount fan. Medium to Heavy Duty ...
MaxxAir 30 in. Industrial Heavy Duty 2-Speed PRO Drum Fan-BF30DDORGPRO ...
KINCROME Heavy Duty Floor Fan 20 (500mm)
Tower fans are also round, but in a narrower column and vertical. I've never taken one apart to know for sure, but I'd think they're an enclosed squirrel cage.
EBMPAPST EM2518LH-113 lu -5.1 SQUIRREL CAGE COOLING FAN | eBay
Oriental Motor ORIX MF930-BC AC Fan Compact Squirrel Cage VFD Cooling ...
The common box fan is kind of an outlier and may be shaped that way to fill space when sitting in an open window or to allow it to stand with less support.
Reactions: JTsyo
