Hey guys
I've got an Athlon 64 3200+ (socket 754, Newcastle core, running @ stock), currently being cooled by a Thermalright SLK-948U with a Thermaltake A2016 fan (80mm, speed adjustable), using Arctic Silver Ceramique as the TIM. My idle temp is around 42 degrees, while under heavy load (Prime95 for instance), it can reach mid 60's! I'm using MBM 5 to monitor temps.
I run the A2016 at about 4500 RPM, as any lower just doesn't work that well and any higher is too fricken loud. :|
I also have a Leadtek A400GT TDH (6800GT) that idles at about 59 degrees, and under load has reached 85 degrees.
My case (CMStacker) has pretty good ventilation, with 80 + 120mm intake fans plus 80 + 120mm exhaust fans... the irony is I have to run the chassis open.
