Are these computer parts compatible?
Davidh373
2,428
looks pretty good. I'd say you can do a lot better with an Intel CPU. The Phenom II X4 is a bit old.
Chameleon_911
15
That looks awesome, but unfortunately I'm from Canada and newegg.com doesn't ship to us.
Edit: Found the Canadian version: http://www.newegg.ca/Product/ComboBu...t=Combo.617105
Then I found this one: http://www.newegg.ca/Product/ComboBu...t=Combo.569871
It may be $100 more, but the PSU is 700W instead of 430W. The graphics card I've been planning to use should have at least 450W to my knowledge.
So is there any difference between the two? Or does it not matter and I can save $100.
Oh, and how much of a problem will the bottom mounted PSU case be?
mfenn
22,400
www.mfenn.com
Before I begin ordering the parts, I'd like a second look to see if I've missed something because I am an amateur.
Everything is in this picture: http://img714.imageshack.us/img714/1340/computergoodcopy.jpg
I'm expecting this to play new and TBR games at decent+ quality.
Compatible? Yes.
However, I would advise against buying a GTX 460 SE. That's a horribly gimped version of the GTX 460. Here's an MSI GTX 460 for $150 after $25 (USD) rebate.
Also, a 500W PSU would work just fine. Hell, a quality 400W is enough.
Davidh373
2,428
It would probably be best to take small combos or even no combos over a DIY build.
AMD issues
1.Seagate HDD
2.Mobo is overkill
3.RAM is overvolted
Intel issues
1.Seagate HDD
2.Crappy PSU
3.Overvolted RAM
mfenn
22,400
www.mfenn.com
Chameleon_911
15
Well I would prefer an AMD, but the guy posted an Intel build. Because I am too inexperienced to know the problems with parts, I used his.
I take it I should make another topic for a build recommendation, but I don't want to create spam on this forum. If you could help me with a list of parts on this topic I'd appreciate it.
I have a total budget of $1000 (shipping and tax included), and I want it to play new games well, and of course be an AMD. I'm going to build it from scratch, except for my keyboard & mouse and my 1680 x 1050 moniter.
mfenn
22,400
www.mfenn.com
Didn't mean to imply that you shouldn't go Intel. I just figured that your original choice was budget driven. A i5 2500K is a much better choice than a X4 955 IMHO.
Chameleon_911
15
Lol see XD. I really don't know anything, and a recommendation from you would be great. Intel is fine, just I don't trust my judgment with picking out parts.
Chameleon_911
15
What David recommended is fine, just swap the RAM and mobo to the ones that I pointed out.
You mean the CPU and mobo? =P
Oh, and because that Sparkle GPU is out of stock, would is make any difference if I went with the MSI version of it?
Davidh373
2,428
He's in Canada, remember, but usually I just buy whatever is the cheapest after shipping. They could very well be from the same manufacturing line in China as far as I've been able to tell lol.
Chameleon_911
15
Will I need to buy a USB network adaptor or does some part in that list have something built-in to pick up wireless networks?
