Originally posted by: propellerhead
All electronic does not mean not analog.
Originally posted by: notfred
It's off by a percentage, not a set amount (unless it shows 5mph when you're not moving, then maybe the needle got bent or something).
My car is within one percent of accurate, based on mile markers on the freeway. Drive 10 miles, measured by mile marker, and also measure your odometer readings at the start and end. It should be 10.0 miles. if it's 10.1 miles, you're off by about 1%.
Thank you.........only an idiot nitpicker would say "But the numbers are analog"..........well, DUH! Surprise, we only read analog.......don't suppose you know anyone who can read pure digital information with their eyes, eh?
Ditto with C'rider. No one reads bloody digital fluent!
Originally posted by: alkemyst
Once GPS's make it into all vehicles speed will probably just be based off it. That would be the most accurate I believe. Also any speedometer will be off a slight bit as tires change in size as they wear or the pressure changes....also different makes have slightly different rolling diameters. In most areas, it is also why speeding tickets do not carry a point or fine penalty for 4mph or under....
