Are Sound Cards worth it?
LOUISSSSS
8,771
58
i can DEFINITELY tell the difference between onboard realtek and my asus Xonar DX.
speakers used are M-Audio LX4 and headphones are SHURE SRH840. Improvements in range and bass and clarity can be heard on both listening devices...
Googer
12,576
7
I can too, given that I have proper headphones and/or speakers. But when it comes to Logitech x or z-whatever speaker you're not going to hear much or any difference at all.
Googer
12,576
7
Hey, I was just wondering how much better the sound quality is on a sound card than onboard sound. I am somewhat of an audiophile and can appreciate good sound quality when I hear it. I'm not one of these people who fall for the Bose nonsense, I know real sound quality when I hear it. After knowing this do you think I will appreciate having a good sound card? I've never really heard sound from one before.
Provided you actually have audiophile, studio, or reference grade headphones then the differences are quite big. But if your using low end powered pc-multimedia speakers (EG: Klipsch, logitech, altec, etc), then the differences will be minimal to non-existent.
konakona
6,285
this.
I kinda wanted to try those SRH840s, missed out on the sale when they first came out :(
borisvodofsky
3,606
You have 2 Choices
Get an Xfi-Extreme Music, and MOD it with new opamps, short muting transistors, and replace 3 of the power caps, 2 for opamp, 1 for MAIN power. <- u can google this.
OR get a Digital capable speaker set, and just use ur onboard for digital out, and let the speakers do the processing.
ON BOARD SUCKS. even ONBOARD xfi sucks. XFI sucks period, so does Xonar, and everything that has muting transistors.
CKent
9,020
No. If you were an audiophile you'd never be satisfied with sound coming from a computer. So let's cross that off of the list. If you were an average user, you'll probably be satisfied with the onboard HD audio that's on today's motherboards.
I can tell the difference when using something like a Creative X-Fi over my onboard audio which uses a solution from Realtek. I run my sound through a Logitech Z-5500. However, I just don't bother. It's one of those cases where I'm ok with the onboard sound. For instances where I really want to enjoy a movie or music, I go to my 50" HDTV and sound system.
Obviously this is a highly subjective issue and for other people, they'd say that there is no way in hell they'd be satisfied with onboard audio. So I'd say most people would be satisfied with onboard audio but it's a YMMV thing.
Disagree, it's not a yes/no thing. There are degrees of audiophilia, especially when you're sane about the amount you're willing to spend. A $99 sound card (Xonar DX) was a great buy for me, perfect balance of cost to quality for what I was looking for and willing to spend.
Fwiw Creative's cards are generally considered pretty bad-sounding. Even the x-fi. And with multi-core processors being the norm now, their monopolistic ability to relieve the CPU of sound processing is much less appealing than it used to be.
konakona
6,285
You have 2 Choices
what makes you think the DAC section on the 'digital speakers' do a better job at that? Speakers can't play a digital waveform, there is going to be analog conversion happening somewhere. More often than not if it is less than a dedicated hardware (i.e. usb dac), the quality seems to get worse for the obvious reasons of cost cutting.
Googer
12,576
7
:thumbsup: :thumbsup:
Well said.
All you are doing is moving the digital (0101001100111) signal conversion from the sound card on the motherboard to the "sound card" in the speakers control unit. Somewhere along the digital signal path it must go from numbers to an analog signal. And chances are in the speakers, they use a much cheaper, lower quality DIGITAL ANALOG CONVERTER (dac) than the one in your motherboard; this is especially true if you have a mid priced or better motheroboard (Asus, DFi, Gigabyte) where they often install something comparable to an X-Fi; this is especially true if the audio comes on a separate audio riser card.
borisvodofsky
3,606
Well said.
Keep stroking your short e-peens. DACs are NOT the problem when it comes to cheapo sound "including the X-fi". Signal Path is the problem. It goes through too much garbage. Whatever sound not coming from a convoluted path is the correct choice.
So he could get a better PATH with the Sound card,,
OR a seperate speaker with digital in with INFERIOR DACs woooo.... will still sound cleaner.
desolate
113
I have an HT Omega Striker 7.1 and it sounds much better then my onboard sound, I love it and you can get it for only about $80 on newegg
43st
3,197
Anytime you can increase DAC quality, you will notice an improvement in sound quality. So yes, a sound card can offer a drastic improvement.
CKent
9,020
You're the one doing all the stroking. Sure the interior of a PC is electronically noisy, but it doesn't mean a better DAC won't make a difference. Many of us have experienced it making a big difference firsthand. Get off the horse.
Googer
12,576
7
I will give you a tad bit of credit, yes there is a lot of psudo junk science involved with anything audiophile related (eh-hem fancy cables). But when it comes to DACs there is a lot of difference between cheap and expensive.
It's almost obvious the equipment you have connected is of lower quality. If you had higher quality transducers and amplification you would immediately notice the difference between low cost dac and more expensive options, from Burr-Brown, Wolfson, ESS, Cirrus Logic etc.
With my AKG K-702 headphones the differences are strikingly clear between onboard, my crummy vintage 1997 sony discman, my low end mp3 discman (gift, 2001?), and my X-Fi Pro (Burr Brown or Cirrus Logic)
If all of these audio samples made by different recorders* sound the same to you, then your audio setup needs an upgrade. Think of it as a Nokia Monitor Test for your ears (eg, the shades of black and white).
*(Sony PCM-D1 is the gold standard benchmark)
CraigRT
31,440
Nah. I just use onboard. Actually I read reviews of which onboard chips were decent all things considered (not sure of link now) and some are decent. I guess the ALC889 is not that bad. I'm OK with it (that's what mine has)
trek
982
I like both so I don't have to swap cables around to switch between headphones and speakers since the physical connections are buried under my desk somewhere. Generally have music going through speakers with onboard sound and play games with headphones through the sound card.
Googer
12,576
7
I have seen little switch boxes that allow you to swap between two different listening devices. This would allow you to run both your headphones and speakers from your add on sound card and allow you to disable your onboard audio; thus freeing up CPU cycles, giving you better system performance.
Plantronics makes one, but their stuff tends to be of so-so build quality that tends not to last long.
http://www.amazon.com/Plantronics-PC-Headset-Speaker-Switch/dp/B000069E1V
I'd suspect, but do not really know that this one might be of higher quality.
http://electronicsusa.com/mk1and2.html
This one has a microphone connection, it's $2 more and is my personal choice and according to the website
"In Use by the U.S. Air Force!"
http://electronicsusa.com/mk5.html
Based on my past experience with Plantronics, I'd take the gamble on the other brand.
borisvodofsky
3,606
ME doing the stroking.. I honestly wish I could.. But you seem to be the one that keeps telling everybody to throw money at the issue,, Oh yea,, "my AKG K-702 ($2-300)" is awesome clearrrr, awesome,, stroke stroke stroke... wooooo burrr brownn....
Googer
12,576
7
I would not make fun of something you have no experience with. You sound like my mother when I upgrade my PC: "What's wrong with the one you have?" "It works doesn't it?" "Aren't they all the same, IBM compatible?" or my grandmother when I buy a new video card and she sees the windows desktop: "I don't see any improvement in the picture quality"
When it comes to audio you can use video for an analogy/comparison:
Most low end video products produce colors (aka sounds) that are not life like or true to the original. Some screens are blurry, not very sharp. Low end audio from a cheap dac is like watching 480i b&w on a color tv. Or good quality amps and dacs on speakers that are inferior (logitech, bose) is like playing a blu-ray on your 1970's Zenith Space Command TV. Another would be, having a high end 1080p TV and insisting that DVD is good enough, there is no difference for blu-raaaaay, stroke stroke, stroke, nvida gtxxxx, stroke.....
Ancalagon44
3,274
202
I cant really comment on the audiophile side of things, since I'm in no way an audiophile, and probably wouldnt know good sound quality if it hit me in the face. I will say, I like the way my X Fi sounds, and I like the fact that it has that feature (X Fi Crystallizer) that is somewhat able to restore some lost fidelity to MP3 sounds. It does sound better with it, yes I'm sure its no substitute for the real thing (a CD) but it makes MP3s sound quite a bit better.
Sadly, Vista and Windows 7 both hobble sound cards because of the new way in which sound is processed, making hardware sound acceleration impossible. Unless theres been some new development in the last few years, things like EAX just dont work anymore, and so all fancy sound processing has to be done in software.
With one caveat - OpenAL - which is an interface that Creative uses to allow hardware sound processing to still occur, and it only works in certain games. Other games can use ALChemy, which converts DirectX calls to OpenAL and so also allows for hardware sound acceleration. I remember hearing that Asus has a better solution than that.
Point being, the way that Vista and 7 handle audio, the rising quality of onboard audio and the rising power of CPUs is all leading towards the death of the sound card except in enthusiast audiophile circles. I'm not an audiophile and dont regret purchasing my X Fi, but these days, if I were building a PC from scratch, I'd probably put that extra money on a better CPU instead.
Spivonious
23
Dedicated sound card will almost always give better audio quality than onboard, but you'll spend $100+. The cheaper cards just aren't going to be that much better than onboard.
To the OP: scratchiness...is it distortion or static? If distortion, then it is your speakers. Computer speakers have built-in amplifiers, and obviously they can't cleanly amplify the sound without audible distortion at the volume you are asking for. If it's static, then it's most likely a hardware resources issue where the soundcard cannot be fed audio data quickly enough.
terentenet
387
On-board is better than what it used to be some time ago, but it's very low to low quality-wise.
You will get a better sound from a dedicated sound card. But those take you only to medium quality.
The best solution with PC audio is a good dedicated sound card that's only used for transport to an external DAC and AMP. X-Fi Music for example, use digital out to a high quality DAC based on the higher grade chips (Wolfson, Burr Brown, etc).
In search of a better sound (headphones), I've been through all stages; Sennheiser HD595, on-board, went to X-Fi Elite Pro and heard the improvement, then went to Asus Xonar D2 and heard the improvement, bought new Denon AH-D5000 headphones and there was a big improvement, then went to Essence ST and there was a big difference, helped the ST with an external Opera Analog AMP and there was a huge difference;
bought a Corda StageDAC (Wolfson DAC's in dual-mono configuration) and the difference is night and day.
Right now I am using Xonar Essence ST as transport (digital out) to Corda StageDAC -> Corda Opera Analog AMP -> Denon AH-D5000.
This setup keeps me happy and the sound quality is high enough that I can hear the difference in cables between the DAC and AMP. Copper cables give me more bass, recessed mids and soft highs. Silver cables have lower bass response, direct mids and crisp highs. I have settled for custom made hybrid cables, solid silver & OFC copper, that have very good bass response, slightly recessed mids and crisp but not harsh highs.
It's too bad some consider the investments in sound equipment mumbo-jumbo stuff... we're talking about our ears and hearing here and it's a one time investment, once you get the good stuff it will last you, unlike investments in video cards and cpu's....
AndroidVageta
Banned
Mar 22, 2008
2,421
If you have cheap headphones costing less than $220 or powered speakers less than $500 in price, you wont likely notice the difference. Wear a pair of Mid to high end Beyerdynamic, Sennheiser, Grado, or AKG headphones and you will quickly become very picky as to which soundcard you listen to.
If your looking for additional perfomrance, hardware based soundcards like X-Fi and XONAR still provide up to a 10% boost in 3d performance. However the only caveat is that support for hardware based audio is slowly fading away and those performance gains in the future will be less and less untill there is none.
This might be a tad off topic...but even if the option for hardware accelerated hardware disappears from games...if you have a sound card, wouldnt that audio still be "hardware" accelerated? I mean, if a game doesnt support it, its not like the CPU is processing the audio then just passing it through the sound card without it doing some kind of work, right?
I might be wrong, but it would seem to me that if you have a dedicated sound card you are always going to get hardware accelerated sound, no matter what the options in a game are...
terentenet
387
Hardware accelerated sound means that the sound card driver pass the sound effects processing directly to the sound card, therefore offloading the CPU.
Not having hardware accelerated sound means that the sound card driver will pass the effects processing to the CPU, it will calculate the effects, then pass the info to the sound card that will only act as a DAC.
With today's CPU's, when we have more cores than we need, if one of the cores is dedicated to process the sound, there should be no performance impact.
LenniZ
I can say yes, sound cards are definitely worth it. My first sound card was an Audigy 2 ZS back in 2003. At first I couldn't really notice the difference, but after a few months I began to notice it whenever I went back to onboard audio on a different computer etc. I wouldn't call my self an Audiophile, I only use some Sennheiser HD555's connected to my computer, but I can notice the difference very well. Right now my ears puke if I hear onboard audio. Its shit.
It's like wide screen monitors, you don't know if you need it at first, but once you get used to it, you never want to go back. :)
Now I recently swapped the good old Audigy card for an Xonar D2X, and I can't say anything else than it gave my headphones new life. I see now that I should have bought the STX instead because of its built in headphone amp.
Most people just don't understand the use of audio cards and spend all their money on videocards etc, but in my opinion the sound is just as important as good graphics for for a complete experience.
