Originally posted by: Falloutboy
Originally posted by: MathMan
I think some people here are confusing direct-view CRTs with CRT rear-projection.
In terms of image quality, absolutely nothing beats a direct-view CRT.
CRT rear-projections are, for the most part, just a very cheap way to get a very large viewing area, but what you gain in viewing area you lose in image quality. Not to mention they are quite large and heavy.
If your priorities are large viewing area first, then price, and image quality a distant third, then CRT rear-projection is your TV.
If your priorities are image quality first, then price, and viewing area last, then a direct-view CRT is your TV.
If your priorities are image quality first, then viewing area, and price last, then a plasma is your TV.
If you value image quality, price, and viewing area equally then a good DLP RPTV might be your best choice.
this is incorect the HIGH end Crt RPs still beat DLP when calibrated profesionaly, but that more work than most consumers want to do to get a good setup, thats why DLP and LCD has taken over that market
Originally posted by: MaxDepth
I am still waiting for the Sony 34" WEGA® Flat Screen HDTV (KD34XBR970) to go down in price.
34" will capture the same height as my current 4:3 TV and the extra inches on the sides are HDTV bonus. Anything less and I cut into the height that I am comfortable in viewing. I mean regular TV shows and not Widescreen movies on DVD.
For me, LCD and Plasma are too "sparkly" for my tastes. Maybe I am not viewing it correctly but I see pixels on those types of TVs. The CRTs soften the edges as I view it.
Originally posted by: aswedc
I just bought one. Same picture, why would I want to spend twice as much for a LCD?
Originally posted by: AbsolutDealage
That's my TV. However, I heard some rumors on AVS that they were swapping out the tubes with some crappy non super-fine-pitch tube. I havn't kept up with it though, so maybe it's just a rumor. You can still pick up this set for ~1200 or less, and that's a good price in my book.
I think all KD34XBR970s have the non-Super Fine Pitch tube, which I guess is why the set is so much cheaper than the 960 was (my mom paid $2200 for hers last summer, but at some point they dropped it to $1900; as far as I know it never went lower).
sucker
Originally posted by: Amused
CRTs still offer the best black levels for low light theater style viewing.
I've yet to find a DLP, LCD or plasma that looks as good as my professionally calibrated CRT RP in a dark room.
Granted, for high light TV viewing, DLPs are better. But if you're into movies in a darkened room, CRTs will walk circles around a DLP.
This is why the best high end FP units are still CRT.
You mean irrelevant?Originally posted by: Thraxen
Originally posted by: Demon-Xanth
I'm waiting for SEDs to hit the market.
Indeed. SED will make everything else in this debate a moot point.
Originally posted by: BurnItDwn
I have a 61inch rear projection CRT. It's a toshiba with three guns on the inside. I calibrate it about once every two or three months as things can vibrate or shift due to noise, etc. The thing is huge. It's not high definition. My couch is about 7-8 feet from it. When I'm watching DVD's the image quality is perfect. The blacks do indeed look very black. The whites do indeed look very white. I have a 27inch HDTV LCD as well. While the 27inch has a much higher resolution, the image quality for movies and such is far inferior.
I fully agree with those who are saying RP CRT is NOT obselete.
Just because it's big and bulky doesn't mean it's obselete. IMO the Plusses Outweigh the Minuses.
Now if only I could find a 1080P 60+ inch RP CRT with duel link DVI input .... WoW would be great on a 61inch at that kind of resolution 🙂
Why Holy Moly?Originally posted by: DonVito
You sit 7-8 feet from a 61-inch TV? Holy moly!
Originally posted by: spidey07
No.
Given it's the best display technology from a quality perspective, AND it's less expensive I wouldn't call that obsolete.
No.
Are you referring to CRT direct-view or CRT rear-projection?
With the exceptions of weight and case depth, i fell CRTs are still just as good as plasma or LCD tvs.
I was referring to rear projection, but could be applied to front projection.
I was under the impression that direct view suffer from limited resolution when trying to display HD due to the raster. I've seen it when I put HD resolution test patterns on them.
