RoloMather
- Sep 23, 2008
- 1,598
- 1
- 0
a 300w electrical space heater create the same amount of heat as high powered computer which is eating 300w of electricity?
electronical? That's not a word.
But that's the thing, YOU ARE releasing it into the world because otherwise you wouldn't need to heat your house since all the heat would be contained. People heat their houses because the heat escapes and they constantly have to replenish the supply of heat.Since it's gotten cold I've overclocked my computers higher, and am running Folding@home to work the processor. I might as well do something useful with my energy use instead of just releasing it to the world.
Ever heard of "conservation of energy"? Unless you're somehow managing to turn it into mass, yes, the end product is heat.
a computer that is absorbing 2 1/2 amps (about 300 watts) will generate as much heat as a heater absorbing 2 1/2 amps (about 300 watts) (assuming both are 115 VAC).
it's not like the energy that does into the computer is sucked off into the ether or an alternate universe. hard drive dissipates 10 watts, CPU dissipates 90 watts, graphics card dissipates whatever ... etc.
you might feel the heat sooner with the heater, and it might be more portable.
I raised the question because I do not really rush to putting the PC to sleep every time I leave the room while it is cold outside because I have always figured it is either that or a space heater (which does nothing else but releases heat).
Really, I figured heat was a form of energy, while light, movement, etc were forms as well, so when a computer is running x % of the 300w is creating heat, x % is creating movement, x% is creating light etc...
So does this mean a server rack with 1500w worth of servers is actually producing the same heat as a huge baseboard heater? I guess it kind of makes sense.
Also makes me wonder why data centers and server rooms spend so much money on AC and heat (for rest of building) when the heat from the server room could be circulated into the HVAC system for other rooms, and cool air from those rooms could feed the server room. only when there is not enough cold air left in the whole building is where you'd need AC, and want to turn off the dampers appropriately, and exhaust the heat outside (though the AC coil).
I used to be confused by how a heater could be, say, 95% efficient, because as we have learned in this thread, unless you are creating mass, its going to turn into heat. But of course the 95% part means that 95% of the electricity gets turned into heat where you want it.
The advantage of a space heater is you get the heat where you want it (circulating in the room) faster than a PC probably will
Electrical resistance heaters are 100% efficient. Every watt that goes through them turns into heat. Even the losses on parts of the heater that aren't the heating element (resistance in the wires, etc) is turned into heat.
I had thought I'd seen some electric heaters that listed an efficiency, but maybe I'm just going crazy
I know that, its just that heat lost into internal components won't heat the room as effectively (ie, it won't radiate as much of the heat as quickly as the coils will).
If you have 1500W worth of servers, you are probably generating nearly that (but slightly less) in heat.
Your datacenter heating / cooling, that makes sense in the winter. Not the summer.
well if you are looking at a heat pump instead of a space heater then they will often list ~300% efficiency. And no that isn't even a violation of the laws of physics. They are just moving the energy around, not creating or destroying it.
They are just taking the coefficient of performance and making it into a percent. Not fair circumstances.
