The card got bent pretty bad, due to the weight of the AC Twin Turbo II and nothing to stiffen the pcb so I found a solution to bend the card back and holding it in place
btw: That PCI bracket holding the card up does not even show when the sidepanel is installed on my CM Storm Scout, due to the sidepanel having one 120mm red led fan covering that area. Also the 120mm fan in the sidepanel is feeding the two Twin Turbo fans directly with fresh air. Helping even more on the already great temps.
Ah. The pencil mod.![]()
How are the Vram temps. The one problem I always noticed with the Accellero products is the passive heatsinks don't cool the vram as well.
Just got my Twin Turbo II installed on my Evga 670 reference, and yeah, its like night and day. No more annoying fan hum/grind sound, and load temps dropped...
Almost 30 degrees.Was topping out a bit over 80, now runs in the low 50s. Clock is now boosting to 1110 at stock as it "should."
Seriously poor stock cooling for such an otherwise good card imo.
I considered the Mono version, but everywhere I looked the Twin Turbo II was the same price (got it for $38 from Ncix).
Time to do some overclocking later.
Congratz! :thumbsup: You have any coil whine from your reference card?
That looks awesome!
That looks awesome!
I wonder how much it will cost.
Price isn't bad for water cooled when you consider it includes EVERYTHING for a true water cooled card. If you already have a water cooling system for your cpu, a water block runs @ $130.00 and has the advantage of covering both the gpu, vram and memory. However, this system includes water cooling for the gpu, heatsinks for all of the memory and vram AND an Active fan shroud system to cool it all. Price all of that seperately and the price isn't that far off.Says $180 - too much! Nice idea though...
I get some coil whine on my Asus 670 DCII, and the card maxes out in the mid-70s with very conservative default fan profiles. I can barely hear it over my 7v-modded Nexus case fans.
It's not quite as good as the TTII (had one of those on my previous card), but if you're looking for a 670 that doesn't require an aftermarket cooler, the DCII seems a good bet.
The only thing that annoys me about this card is the driver bug that seems to be causing a lot of stuttering with vsync on (which is always the case for me).
Yeah it was a close call for me, decided on EVGA + TTII for a bit of extra $$. Wanted the EVGA warranty/service and if the TTII fans go bad you can buy a replacement for $7 from the AC website.
off topic: Now if I can only find a pwm fan that doesn't "tick" for my cpu cooler (both Scythe's I have bought have had this...sigh). Trying out the AC pwm fan tonight. I don't mind noise coming from my computer as long as its a pleasant "whooshing" sound.
I fail to see the benefit with this watercooler. With the Twin Turbo II I get 45c degrees in the most demanding games (custom fan profile), overclocked and silent. Cannot hear the fans over my case fans.
Even if this watercooler did bring the GPU down to 35c degrees, so what? There are no possibilities for upping GPU volts anyway. And if so, the Twin Turbo II would handle that without a problem.
Also, it's much more expensice VS the Twin Turbo II.
With regards to watercooling I can only see the benefit if a system have some custom watercooling on the CPU too, and add a block who covered GPU, Vram and vrm.
Stoneburner and DeeJayeS, have any Coil Whine under load from your cards?
I'd recommend trying a fixed-speed fan, and either using the motherboard or an external controller to set the fan speed. I use a Scythe Kama Flow 2, and it's really, really quiet, with just that "whoosh" you're looking for. Goes up to 1400rpm, but with a manual controller, I usually set it around 1100-1200rpm, and just turn the knob (which is attached to the back of my case) if I'm running a heavy load on the CPU.
Watercooling doesn't take up 3 slots like your cooler
