Apple 30" HD monitor
Anubis
78,712
427
tbqhwy.com
Originally posted by: Tylanner
Originally posted by: KPSHAH316
in anubis' defense, how many games are on the mac:p Thats right, I didn't think so.
Is it a Mac only Monitor?
no you can hook it to a PC if you use a workstation graphics card, the Nvidia Quadro FX 3000 is the cheapest PC card that has Dual Link DVI at about 1000$ i think, the ATI Fire GL? card might be a lil cheaper but its close
Koing
Elite Member <br> Super Moderator<br> Health and F
Oct 11, 2000
16,843
Wouldn't the Nvidia 6800DLL work in a pc also?
You can just set the resolution lower and it will run games for the pc.
I run games lower then he 1920x1200 res on my 23" Sony Lcd. Games look good enough at lower resolution imo. Your not watching a static screen like if you run a Lcd at lower then it's native resolution like when you are using windows. You don't need text to be as sharp.
Unreal II was fine on my screen. A bit of ghosting but I can over look that for the sheer size of it.
The 30" wouldn't take much depth on my desk and that is what is important to me. It would take the same as my current lcd. Just a lot wider and taller :p
I wonder how much it will go down to in a few years?! 3yrs time if it gets anywhere near £1k I might have to get it and if it runs on the dam graphics card I have at the time. I'm a slow upgrader of graphics card as I don't game much.
Koing
TitanDiddly
Guest
Dec 8, 2003
12,696
Set the background to a windows logo before you leave.
Better yet- go home, use your programming skill to make a screenaver file that emulated the XP pro loading screen.
Anubis
78,712
427
tbqhwy.com
Koing
no theres a big thread in gen hardware about it and a big on on hardforum about it also, someone there actually hooked one to his PC useing a Quadro FX 3000
Koing
Oct 11, 2000
16,843
Oh I see.
I'll go check it out now.
Thanks
Koing
amol
11,680
i was in the pasadena apple store on saturday . . .
30" is SERIOUSLY huge
the screen on the 20" imac is also pretty good . . . its the only think i like about the new imac; only thing is, they had the exact same screen on the old imac, and i liked that shape better
Koing
Oct 11, 2000
16,843
http://www.harmony-central.com/Test/wilson/two.jpg
wow!
One 30" Apple and the IBM AND a second IBM on the right hand side :cool:
Koing
you didnt tell them that thoes browser windows are THE SAAME SIZE in Pixels
Well I figured that you guys would suss that out :p
But yeah I was showing the point as this dude has two of the IBM screens and one of the 30" apple screens one dam desk! That there is about $16k at least of screens! But he somehow got a big discount.
Koing
