APC 500VA UPS for $30 in store. Do it on line, possibly free.
soflawill
1,514
Tried to order this afternoon. Mine went up in price in the middle of placing the order online. Started out at the 29.99, ordered two, used he coupon, gave the cc info, and bam-charged up at 99+. Had to call to cancel the order. (*&^%*&^%*&^% couldn't believe it-in the cart at 29.99 then checkout at 59.99. Thats what I get for spending the morning actually working!!
:disgust: :laugh: :disgust:
nablio
156
Same thing happened to me, the punks. Still, $20 ain't too bad...
GtPrOjEcTX
10,784
Originally posted by: GtPrOjEcTX
just bought 2 online for $52 after taxes and after $10 off $50 coupon, free delivery.
I'll mail in 1 set of the rebates (each with real UPC :) ) so I'll end up getting 2 for $22. awesome. I was planning on doing one for the $30 AR that was in the ad, but this is much better.
awesome, my 2 are out for delivery today. and wow, 32 pounds to ship...that free shipping really came in handy :)
MWWInc
63
I ordered mine online yesterday morning at the $29.99 price. When I picked it up yesterday afternoon it was surprisingly heavy.
Now, to send in the rebates... Oh, speaking of, are those of you who did in-store pickup sending in the invoice you got at the store as your receipt, or using the e-mail confirmation, or both, or what?
nablio
156
I'm not taking any chances. I'll try both.
flashbacck
1,921
sorry for the dumb question, but how are you guys getting free shipping? I'm getting hit with a "small order handling fee"
edit: oh duh, I need to add $0.01
flashbacck
1,921
the price seems to be back up to $49. I used a $10 off $50, so with the rebates, it should come out to $13. nice! Thanks OP.
c627627
1,155
Would you please test yours if you got it.
After 20 hours of charging, I disconnected the power cord to get only 24 seconds of battery power for this computer system:
21" monitor
AMD Athlon XP 2400+ mobile IQYHA 0402 SPMW
[185] FSB x 13 = 2405 MHz @ 1.80 Vcore with memory frequency at 100% [185 FSB] @ 2.90 Vdimm
3 x 256MB K-Byte PC2700 (SpecTek chip) @ 6 3 3 2.5
Epox 8RDA+ v1.1
Thermalright SLK-947U with variable speed 80x25mm Thermaltake Smart Fan 2
BFG GeForce4 Ti4200 8X 128MB;
Antec SX-835II case ; 380W Antec TruePower TP380
Four 80x25mm Case Fans + 1 Variable speed 80x25mm Fan YS-Tech FD1281259B-2F
GtPrOjEcTX
10,784
21" monitor
Epox 8RDA+ v1.1
take the monitor off it.
c627627
1,155
The box says 18 minutes with 15" monitor...etc and then it says 7 minutes with 21" monitor, isn't the whole point to get a few minutes to finish up what you're doing in case of power outtage? I get 24 seconds with a 21" monitor.
Fallen Kell
537
Yeah and the specs they are quoting for is a non-overclocked system!!! Of course it is going to use up more power!!!! Why else do you think you had to buy a good power supply in order to do the overclock in the first place? If you read the fine print, it is expecting a 250-300 Watt power supply. Not a 400 Watt overclock monster with 5 case fans, a cpu fan, a video card fan and a 2 power supply fans. The specs are rated for you average 2 fan Dell.
If you wanted to see what "your" system's load is, you should have gone to their website and use the UPS finder service to find out what your requirements actually are. I bet if you plug in your system it will tell you the 500VA UPS will last 20-30 seconds.
c627627
1,155
Thanks Fallen Kell, that makes sense.
Also, what's the USB to LAN cable for again?
"It allows windows to track the battery life and for you to set backup procedures (eg. shutting down when battery is at 10%). After 30 seconds of battery usage, my status says 90% full, so at this rate I should get around 5 minutes worth, which is plenty.
BTW, I have a 17" CRT, 350w PS, Radeon 9700 Pro, 2 optical drives, 1 hard drive, 2 fans, 2.4c pentium. I also have my MX Duo hooked up to the battery, since I kinda need mouse/keyboard control to save and shut down)"
jayman7
This guy gets 5 minutes worth, in comparison, I have more case fans, 1 extra hard drive, overclocked system, 21" monitor, which drastically reduces things for me.
ir0nw0lf
409
If it's the same cable that came with my larger APC UPS units that I bought before, it's not a USB to LAN cable. It's a APC proprietary data comm cable that plugs into a USB port on your system and into the data comm port on the UPS. That way the UPS can communicate to the PC for things like shutting down, etc.
c627627
1,155
Its "only" purpose is to inform the user how much time there is before battery power shut off then?
weepul
5,134
www.hd-trailers.net
if ur using the UPS for a compuer, i'd higly recommend you connect the USB to LAN cable to your compuer (USB on computer; LAN on APC unit). then install the software that comes with the bundle. I believe it's called PowerChute. incase of power failure and you're not around, PowerChute will help shutdown your computer when there's like 5mins left (u can preset the time).
The software also tells you how full your battery is and the estimated time it'll be up when power fails. What's weird though is @ 100% battery charge, the software says 83min battery time on a 17" CRT + AMD2000+ 400W PSU. anyone else getting weird readings like that?
//krunk (^_^x)
c627627
1,155
Aren't you all interested enough to find out how much time you really have?
It's the first thing that came to mind, disconnect the power cord and start the stop watch.
It would be nice if you posted your system specs and how much time you lasted without power. It was 24 seconds for me:
21" Nokia 445Xav monitor
Epox 8RDA+ v1.1
Two 120 GB 7200RPM HDs
+ Power to Cable modem + Router
+ Power to 1 Telephone set.
Engineer
701
//krunk (^_^x)
Just a little FYI...Windows XP SP2 found the UPS and installed it's own "METER" and shutdown procedures (limits). Didn't even have to open up the CD envelope! :)
Engineer
701
Originally posted by: UltraWide
does this have line conditioning? or just battery backup?
From here....
Back-UPS® ES
(500VA - 725VA)
Best Value Battery Backup & Protection for Home Computers
Product Information
> Model Information
> Features & Benefits
> Service Programs
> Runtime Chart
> User Manual & Installation Guides
> White Papers
> Product Literature
> Customer Testimonials
> Awards & Editorials
- The most popular desktop UPS in the world!
Features & Benefits
Protection
Battery-protected and surge-only outlets Reserves power capacity and run time for connected equipment that require battery back-up while providing surge only protection for less critical equipment
Power conditioning Protects connected loads from surges, spikes, lightning, and other power disturbances.
Dataline Surge Protection Provides protection of connected equipment from power surges on the data lines.
Lifetime data recovery warranty Provides peace of mind by providing professional data recovery services in the event data is lost due to the failure of the unit.
Safety-agency approved Ensures product testing and approval to work safely with the connected loads and within the environment.
Convenience
Audible Alarms Provides notification of changing utility power and UPS conditions.
Automatic self-test Ensures early detection of potential problems by periodic testing of UPS components.
Cold-start capable Provides temporary battery power when the utility power is out.
Hot-swappable batteries Ensures clean, uninterrupted power to protected equipment throughout battery replacement.
Resettable circuit breakers Enables quick recovery from UPS overload events.
Transformer-block spaced outlets Protect equipment with input transformer blocks without blocking access to other receptacles.
Manageability
USB Connectivity Provides management of the UPS via USB port.
Now does that mean that it produces a pure Sine wave or just filters the incoming (including adjustment up via battery power) power? I just don't know.
chiragp
239
Bought this UPS online and picked up instore, same day the deal came out for $30 and out went the rebates very next day. Received an email from ODs rebate fulfillment center (www.teg-online.com) that the $20 rebate is valid. That was FAST!! now hope the $10 APC rebate comes through too !
