AOL IM 5.5 Sucks!
alkemyst
83,769
19
Originally posted by: psydancerqt
triumph.. you sure? there's no option that says "show aim.com window at sign on"??
Truimph if it's 5.5 it will have as psydancerqt says under Setup->Sign On/Off
Å
Triumph
14
nope. i am running a beta version that i downloaded before 5.5 was released, that may be the reason. i'll have to check my home PC after work.
randomlinh
linh.wordpress.com
Originally posted by: Ameesh
you can record your own blank sound very easily but if you are too dumb to do it, i wont help you
it's more of a principle for me.. why did they knock off a very USEFUL feature? Altho they claim you can adjust the aol sounds? i bet that is a global setting too.. can't do each individual sound.
but yeah, i'd use trillian.. if profiles worked properly.. and if it didn't cost $25. There was a bug in which links in the html profiles would always open up in IE.. i dont' want that. And idle times get screwy as well. gaim would be nice if it didn't pause on my system every so often, and had an externally access history.
