ANyonme encounter this problem with SiSoft Sandra?
Matt2
I overclocked my CPU (P4 2.4B) to 2.79GHZ no prob, didnt even break a sweat, stock voltage and everything.
HW MOnitor in my BIOS said the CPU temp was 29*C. Does anyone find that number to be a little TO low?
After I ran 3DMark a couple times to amek sure the sysytem was stable, it was, I looked in SiSoft Sandra for the CPU temp and it said 69*C!!!!!! I immediately restarted the computer, went into the BIOS and checked the HW Monitor and it said 29*C...
What do you guys think?
P4 2.4B @ 2.79 1.5v
Vantec Aeroflow w/TMD fan
Forget what Sandra says, its known to be... well inacurate at best! It informs kindly that my laptops processor is running at 129 C!!!
This is a P3 1Ghz...
Download Motherboard monitor (MBM5) if you want to see your temps from windows.
-DaFinn
what type of cooling is this?
i think that is really low.
My ultimate rig in the signature, idles at 35.5C and load is at about 40C
We really need to know the specs of ur computer since some mobos report the temp wrong
Intel P4 2.4B
Albatron PX845PEV Pro
512mb PC-2700 Crucial (not micorn as I stated before accidentaly) DDR RAM
GeForce 4 Ti4400
80GB Maxtor UATA/100
I jsut dont wanna push this system and fry it because the mobo didnt correctly report the CPU temp.
Right now, I am posting at 2.88GHZ and it says the temp is only 28*C!!!! The system is stable though so i dunno.
Has anyone heard of Albatron mobos reporting wrong temps?
EDIT: Cooling is Vantec Aeroflow w/TMD Fan
