I have them setup as automatic/temp controlled, just did a quick and dirty profile with three temperature/speed points and works as advertised. Originally, I had the Corsair H70 pump connected to the Chassis Header and the fans connected to the CPU header per Corsair's instructions. After reading your post, I started messing around with Fan Xpert and noticed that I could control the pump's speed on the Chassis header and could not control the speed on the CPU header. Switched the connections: Pump to CPU header and Fans to Chassis header and all is well.
Hi ; newby / n00b questions...
I realize this thread has strayed off topic ...
I am trying to digest the info posted here ...
... and I am a little confused .... (sorry )
I just purchased Asus P8P67 ( std / base mdl ) ...
.. and have a few ?'s
1) Can the 4-pin Chassis-Fan header on P8P67, provide regulated control of a 3-pin fan ? ( how ; i.e. what is trick? )
2) Does this ASUS MoBo have a EFI-BIOS or FAN-XPERT setting to switch between PWM and voltage control for the 4-pin Chassis-Fan.
(as was posted in this thread in regards to a Gigabyte MoBo).
3) Does the 3-Pin Chassis-Fan header provide temperature-regulated, variable-voltage control for a 3-pin fan ? ( any special settings? )
& finally
4) any problems with using a ' 3-pin splitter ", connected to the ASUS 3-pin chassis-fan header, to provide variable-voltage to two(2), 3-pin fans ?
thanks for your knowledgable responses ,,
O T
