Originally posted by: Bryophyte
We had our truck professionally done, but I have used the spray cans of it for the inside of my wheelbarrow. Works great for that application.
Ha, I was going to use it to spray the chute on my lawnmower's snowblower's chute so rocks didn't scrape it up too bad.
What brand did you use for your wheelbarrow?
Whatever brand they had in the spray-paint section at Fred Meyer. Nothing special, I think. We used the leftovers to paint out wear spots on the deck of our tractor (taped off sections to spray, it looked like it was done by the manufacturer.)
Originally posted by: Eli
I bet it could work good, but you probably have to make sure that the bed is REALLY clean for it to adhere well.
Does the surface have to be 'etched' in order for the spray-on bed liner to adhere?
You herculined your computer?!
Originally posted by: myusername
Just clean it until the rag wipes clean.
edit: yzzim - It says to etch in the herc instructions? I thought that was only for aluminum, and just recommended,not necessary. Or did you mean scuffing it with the scotch-brite?
Originally posted by: JulesMaximus
Sell your truck and buy a Prius.
Edit-Just kidding, Line-X is top notch. That's what I would go with. I had a Line-X liner in my Tundra and it was pretty much indestructible. Rhino liners end up looking like crap after about 6-8 months (all dull and faded). Those do-it-yourself kits look pretty bad too, at least the ones I've seen.
Have you seen Herculiner/Durabak? That seems to be the "standard" of DIY bedliner. I haven't seen either in person, but I have the internet
Also, anyone happen to know of a softer rubberized liner instead of one that hardens like plastic? The sort that has enough grip you could, for example, drop a wrench on it and it wouldn't go sliding around when you went around corners? Would be less durable, but more sound absorbent, and (duh) things wouldn't bang around corner.
Which spray-on brand hardens to like plastic?
