anyone use EAC to rip their CDs?
Originally posted by: Nitemare
That's weird, just reinstalled EAC and used Lame to rip a whole cd of mp3's devoid of sound 😱
Double checked my settings and everything is ok, even the dolby bar is moving when they play empty air.
I had something like that happen on a couple computers I set it up on... I had to check one of the boxes for the CD-ROM drive settings to fix it. It's been awhile, so I can't specifically recall which one.
After I disabled the copy protection thing under EAC it worked fine.
Originally posted by: conjur
EAC with LAME set to --alt-preset extreme
That's all you need. 🙂
Extreme is overkill. --alt-preset standard should be perfect for 99% of CDs out there.
Harddrive space is cheap. 🙂
Very true... can't wait until FLAC is the norm 😉
