Anyone use Cool n Quiet?
imported_FishTaco
1,120
Assuming you have an AMD64 not an AMD64 X2, and that you have Windows XP, then you'll probably want the one called:
AMD Athlon? 64 Processor Driver for Windows XP and Windows Server 2003 Version (exe) 1.3.1
I haven't touched AMD's CnQ stuff in over a year and a half so I might be wrong.
archcommus
8,115
Originally posted by: Heen05
well i downloaded it and installed it and restarted...but i dont see anything...any ideas?
Check the CPU speed in System Properties, is it low or stock?
For me, it remains at stock. Go figure.
Maximilian
12,604
15
I remember when it came out alot of people didnt like it...but how is it now?
why wouldnt i use it? any problems or anything? i wouldnt want it to not speed up by accident when i really need it. thanks
I think a lot didnt like it because it wouldnt work for them and they were jealous :p That was my position anyways.
I use it in my new 2.5ghz opty, works great no problems. Apparently you shouldnt use it when overclocking but thats bs im fine with it.
imported_FishTaco
1,120
Sorry, those are the only things listed when starting AMD's CnQ. I remember back when I got CnQ working, which was over a year and a half ago, I couldn't use the then current version of the processor driver, I had to use an older version to get it to work and even then it didn't downclock the processor that much. All I can suggest is give RMclock a try if you can spare the resources, if not maybe post your problem in the CPU/Processors forum, they might be able to get the AMD driver working.
