- Jul 14, 2005
- 29,307
- 106
- 106
ouch :~
edit: hm, though you could make/get a balanced to single end adapter.
Yeah. That doesn't seem like an issue. I have all my stuff from when I was into the whole DIY cable thing (Love exact lengths).
ouch :~
Try to wrongly claim all transparent gear sounds different than other transparent gear and make up weak excuses to avoid blind testing demonstrating what differences they can really hear.
less noise (maybe)
moar power
A little known fact is that the signals need not be out-of-phase for common-mode noise cancellation to occur.It is less noise, not more power. The balanced design (for systems that actually use the balanced design, not simply use XLR connectors) sends the signal down two different wires out of phase with each other. This way when an external noise source affects the wire (say a magnetic field), it is assumed that the noise will affect both of the wires is approximately the same manner. And since the signal set between the two wires are out of phase, the errors introduced on the two wires correct itself when the signals are put back into phase and merged together.
I am going to date myself, but if you have a transparency (i.e. a clear plastic sheet that you can draw on and used for overhead projectors before PowerPoint), draw two horizontal lines with an inch or two gap between them with a small hump in the line at the same spot with the same height on each line. That hump is the external "noise" affecting your signal. Now fold the transparency in on itself so that the two lines are aligned with each other and it now looks like one line with a bubble in it. Now if you merged the lines together subtracting the height of the one with the height of the other, you will now have a straight line again, which is your pure signal.
That is what a balanced design does. But as I said, not all things with XLR connectors actually are balanced, because balanced designs were seen as a high-end feature (and they are because it requires some additional electronics to make the signal out of phase and put it back in-phase and merge the two waveform/signals), but it doesn't really cost anything extra to simply put a XLR socket in place, and the cheaper brands/lines saw and knew that, and some of them decided to put XLR connectors on their amp and pre-processors and thus tried to dupe customers into purchasing their product because balanced was a high-end feature, and it looks like they had same connectors on their product which costs half as much as the other competitors which had a true balanced design.
This pretty much says it all:
Anyone who hasn't done a truly blind listening test is kidding themselves if they claim they can hear differences in things like DACs and most amplifiers. You owe it to yourself to find a similarly-minded friend, set up a test and spend a couple of hours testing each other before going out and spending hundreds or thousands of dollars on audio equipment that you think sounds better.
NwAvGuy released his ODAC today (open source, free to DIY) with "Balanced Outputs" listed as "no snakeoil required".![]()
This DAC might give some fresh air to the audio community. Head-Fi sponsors are probably firing up their ammunition. :biggrin:
NO SCHEMATIC: Because YoYoDyne is taking considerable financial risk to produce an unproven DAC in relatively high volume, its not reasonable to have it be open source (see the previous ODAC articles). Once hes hopefully recovered his investment, we plan to re-visit the open source question.
Yeah most of it is snake oil. A whole thread devoted to different USB cables and how they change the sound from a DAC is laughable. But just like any other forum they have their high and low points. You learn to take what makes sense and leave the trash behind
I was asking about balanced setups because Schiit audio is releasing a balanced Amp and DAC soon. I have their current DAC and amp (Valhalla) and really like their products. Got me considering rewiring my headphones for a balanced set up.
You're right. I'd daresay, though, that all well-engineered amps above a certain price point do.I can assure you SS amps do not all sound the same.
I can assure you SS amps do not all sound the same. Its like saying all LCD TVs have the same picture quality given "comparable" specs. Ridiculous.
Yep. Ask an electronics engineer, they'll say the same.I do agree that a well built solid state amp will sound just like any other well built solid state amp.
all ss sounds the same? all topologies sound the same? all opamps sound the same? lol
i don't understand all the benchmark dac1 fanboying either, it's a fine unit, but there's plenty of cheaper options that sound as good. and the amp in it isn't as great as people make it out to be either.
I've listened to one. Doesn't sound better or too different than my Presonus Central Station.
Oh god. Tubes and their distortion. Amazing.
How do you like the HiFiMan HE-6? ever compare it to a sennheiser HD650?
The HD650 has a greater quantity of bass, but that's about it. Where the HD650 has big roll off above 5kHz, the HE-6s would sound quite a bit brighter but have sub-bass that's unreal. The HE-6s are my neutral reference phones, their FR is flat, flat, all the way down to 10Hz.
Personally, I like neutral>bright cans but most people find them to be too harsh.
