I just installed it the other day. Got it from my MSDNAA account. Love that thing.
Does it support C99 (...yet)?
Not really, and I doubt that it ever will fully support the standard. According to the dev team there just isn't enough demand for it to justify the investment.
http://blogs.msdn.com/vcblog/archive/2007/11/05/iso-c-standard-update.aspx
An another point, has anyone else noticed that 2010 occasionally opens solutions in full-screen mode, apparently for reasons of its own? I use a widescreen monitor and have multiple solutions open most of the time, so I never run fullscreen, and I'm not sure where it got the idea that I wanted to.
Nope haven't had that happen. Are you opening VS then having it open the solution or opening the solution directly?
Something else made me super-happy: when you pause your cursor on a variable, all occurrences of that variable within the scope are now highlighted. So if you're in a method and you're processing a parameter, the IDE recognizes that that parameter is part of the method signature, and highlights only the necessary occurrences. KICKASS! I have been waiting for this feature since 2005... good thing MS is listening.
Anyone noticed the camel-cased intellisense? You can type the acronym of a property or method and it will find it. For example, try writing Console.WL and WriteLine will pop up.
I have VS 2005 and 2008 from MSDN AA while at school but I no longer have access to it. I've been thinking about dabbling in some .NET development (primarily have worked on embedded systems and Unix shell dev only) so I may have to just get VS 2010 Express. I'm not sure it's limitations but I doubt for my basic usage that I'd need anything from the Standard or Pro series so I might as well get into the latest and greatest.
I want to stay in embedded development but it wouldn't hurt to expand my skills and all I hear about is .NET and Silverlight and all this fancy stuff.![]()
private int blah;
private int foo;
private int bar;
