I agree. The Hyper-R is the automotive equivalent of a Grand AM with 19's and a Supra wing. Much better PSUs can be had for the money from Seasonic, Forton-Source, PCP&C, ect. If you need modular this Enhance is the one to beat.Originally posted by: GalvanizedYankee
14k, seeing that your not State side limits what I can offer, aside from a real PSU review. Never trust Kick Ass Awards or reviews done by sites with names like KickButtComputers 😀
Read http://www.xbitlabs.com/articles/other/display/foxconn-hiper.html If you read the review it's nothing to write home about after the bloom is off the rose. A Fortron/Sparkle for the same money would be better.
It is not fully modular, the main harness is hardwired.
For our purposes, the face of an ATX PSU is 150x86mm, depth can vary from standard 140mm to 150, 170(iirc),180,185,200 or 220 is the deepest I've seen. The modular connects add depth that can get in the way of deep opticals. So one has to measure to be sure.
This unit will Froogle here in The States for $110 http://www.enhanceusa.com/file/33_specification.pdf
After doing my homework, I bought one.
essasin, The new M12 Seasonics will be semi-modular. The main harness will be hardwired.
...Galvanized
Originally posted by: Howard
Moot point (and rather deceiving). Whatever needs extra power to overclock higher can be given higher voltage individually. Why boost the +12V voltage and risk damaging a HD when you can just go into the BIOS and up the CPU/memory voltage? Just an excuse for poor regulation.Originally posted by: Mem
FYI Hiper tend to over volt a bit on the rails for added stability,this below taken from their homepage.Then we might be all buying Aspire PSUs
.All our PSUs, if measured with a Multi-Meter as software is unreliable, will show our lines slightly above the marked current (i.e 12V at 12.24 for example). This is by design and not a fault. Hiper PSUs are designed for users who will drive their systems to the edge and not for users with one device and a floppy connected. We have to assume our clients may be Over Clocking their components and will need more power output than normal.
Moot points, again. Once everything is installed, there wouldn't be any reason why the cables would fall out (save for a rat or two).Connections are avionic type(as used on aircraft) so virtually impossible for them to come loose unless you unscrew them on purpose,and gold plated pins to prevent rust and bad contact.What's so special about their implementation of modular cables? Unique connectors?
Gold plating the pins might reduce contact resistant, but by a negligible amount. There's absolutely no reason why a well-designed connector would have bad "contact", save for significant surface corrosion, which leads me to my next point - ordinary pins in Molex connectors and what-have-you are tin-plated. Perhaps not as electrically conductive as gold, but it still serves its purpose of resisting corrosion (i.e. no "rust"). The outer layer of the tin reacts with the oxygen in the air to form tin oxide which, like copper oxide, protects the rest of the tin from further corrosion, and furthermore is electrically conductive itself.
In short - ordinary [well-designed] modular cable connectors won't suffer from rust or bad contact.
JEDIYoda, I have wasted enough time on you. I will no longer reply to your inane drivel.
At light load, its rating is a paltry 64.4% - the lowest value for any of the power supplies we tested!
Originally posted by: LOUISSSSS
i dunno what you two are arguing about but personally i wouldn't buy this PSU. cuz 1 its obviously targeted towards the 12-15 age group with the funky looking modular cables. 2. it comes in a fishing tackle box which probably cost half of the psu. 3. a quote from an article reviewing this psu:
64% efficiency is horrid. my fsp is rated at 85%
the overvolting the 12v rail from their website is BS. why would u overvolt for overclockers and 'exteme' users when u can raise the voltages yourself in the bios (as stated by howard). IMO thats poor engineering.
Louis and Howard are right. Please search the forums first because this has been discussed many times and they all outline that you can buy a better psu for the money because the modular desgin is not very efficent at all.
Originally posted by: JEDIYoda
Originally posted by: t3h l337 n3wb
They're not very popular yet, but the Hiper Type R modular PSUs are great. Go for it. I'd still try to buy online though, since it's usually a lot cheaper than in stores.
The Hiper Type R modular is the only modular I would even think about getting!!
They appear IMO to be the only company that does modular correctly!!
And someone said modular cables made the performance worse?Going from Test 1, which was a 338.3W load, all of the way up to Test 4 and Test 5, the Liberty only dropped .16V! That?s better than most non-modular power supplies!
The Hiper modular Seriews PSU`s are excellent!!
They get rave reviews!!
If i was going to go modular thats the way I would go!!
^^ i can't tell if thats sarcasm? or just poorly worded lol
Originally posted by: PrISM506
Does anyone know if it'll work in an Antec P180 case with the shorter cables?
Originally posted by: acegazda
What about the enermax liberty? Johnny gave it a favorable reveiw here. A quote from his article:And someone said modular cables made the performance worse?Going from Test 1, which was a 338.3W load, all of the way up to Test 4 and Test 5, the Liberty only dropped .16V! That?s better than most non-modular power supplies!
They do. If one particular power supply with modular cables beats some that don't in a particular test, that does not in any way indicate that the modular cables aren't a handicap. On a good design, they should not be a large handicap. A well-made power supply with modular cables should still behave like a well-made power supply.
Well said. And very objective (which is rare in these forums.)
Originally posted by: Smilin
My Hiper 580 should arrive tomorrow. It will be placed under a VERY heavy load. Considering what I'm throwing at it I consider this a bit of a risk. I'll let you know how it turns out.
The case on the power supply is beautiful. I only got the plain black one but the finish is like a car. Chrome grill and fans nice. The wrapped cables are high quality, very clean looking and easy to work with. Several lengths are provided including one dedicated for your video card.
My gripes:
1. In my case I'm using every cable so the advantages of the modular design are lost on me. (This doesn't deter from the clean cable benefits though)
2. To remain durable the modular cables are stiff where they connect to the power supply and they protrude a ways. My case design (Lian Li-PC65b iirc) features a blowhole fan on top and the cable connectors made things a tight fit.
