pete6032
Long shot but does anyone have a home CNC machine? I think these look really cool, want to get one but they're pretty expensive.
https://www.inventables.com/
I'm getting near the end of building this DIY 40w laser cutter: http://www.buildlog.net/blog/2011/02/buildlog-net-2-x-laser/
I just finished the wiring tonight. I still need to configure the computer to drive it, wire the laser, setup the cooling, and setup the exhaust ventiliation.
I want to get a CNC router as some point. I'm very likely to go with the Shapeoko 2. I suspect I'll outgrow it pretty quickly, but it's a super cheap starter CNC. $600 to start isn't bad.
build your own with ply/mdf cut with your laser.
:hmm:
I have plans drawn up for one and some of the code figured out to drive the stepper motors but it will be a long time till mine is up and running. I am trying to build it all from scratch including programming the microcontroller thats running the steppers; I may end up using an open source Gcode interpreter so I dont have to try to write that too.
I have plans drawn up for one and some of the code figured out to drive the stepper motors but it will be a long time till mine is up and running. I am trying to build it all from scratch including programming the microcontroller that’s running the steppers; I may end up using an open source Gcode interpreter so I don’t have to try to write that too.
I was thinking of just plinking around with it, but also thinking about making a cribbage board. I have designed a few board in the past and done them by hand but using a CNC machine would take it to the next level.
You read my mind from last weekend. I now think I want a Shapeoko very badly.
Just gave it a once-over and looked at the projects section. Lots of opportunity in non-metallic materials to have some fun. I wouldn't want to do metal though! Or even certain composites.
Looks simple to assemble and maintain, but using a Dremel type of tool as the spindle is a little sad... but anything 'good' will damn near double the cost of the hardware (at least).
I wish good machine equipment wasn't so pricey...
Anyone who has one are they particularly loud?
