Meghan54
Just to follow up....bought a pair of AC Delco Durastop rotors. They're what came on the Blazer originally, did work well for about 100K miles, and the ones I got were American made. Waiting on the brake pads (bought a pair of Hawk HP Superduty pads...semi-metallics) to be delivered today....then brakes are on the schedule for this afternoon.
Bought the semi-mets over replacement ceramics because the semi-mets seem to bite initially better than the ceramics out there, which can make a bit of a difference, esp. in my case.
I've always noticed with ceramics, and my Blazer came stock with Akebono pads, the initial "bite" from them is not quite as good as some semi-met pads. Almost like the ceramic pads need some heat in them before they start to perform well.....and with towing, I need every foot sometimes, esp. when the village idiot cuts in front of you then hits his brakes....hard.
From what I've been able to glean from reading on various sites, Akebono was the originator of the ceramic pad....mostly made in response to requests from OEM's for lower dusting pads that would provide less wear on rotors and less noise while braking. And from what I've read, and take this for what it's worth, the Akebono pads tend to have more ceramic components as compared to other brands.
I switched to ceramics just to avoid the brake dust. Hope I don't regret not splurging for the Akebono ProACTs (got the Raybestos AT instead).
