SpatiallyAware
Well now you know why ...
wtf that's ridiculous. If it needs wiped or whatever then iTunes should handle it - isn't that what apple is all about? Not having to tinker and mess with crap to get it working?
yes as long as you saved your SHSH blobs using umbrella or with cydia . no problemo.
always save your shsh blobs immediately after a new version so you have CHOICE.
3G can go back without blobs; 3GS requires SHSH blobs.
so just JB ios 3 and you'll have all the same features without the lag lol.
seriously.
I've restored my phone with 4.01 and I still have bizarre typo/keyboard lag problems.
It usually happens when the keyboard is supposed to pop up (which usually takes .5-1 second longer than before). It accepts the first few characters before it starts to lag when accepting input. I swear it also seems pickier about hitting the keys perfectly centered.
I'm not going to JB my phone. I had it JB broken, but that messed up the tethering. Ya, i used the tethering that JB had, but that was far worst than the one that's provided by my provider (Rogers).
I'm sick enough of all this crap that i'm dumping my iphone, despite having over a thousand dollars worth of apps purchased. This built in obsolescence is ridiculous. I haven't even finished my contract yet, and now i can't even use my iphone. Yes, i can make calls or txts, but that was only 5% of my iphone usage. I don't like waiting a min for programs to load. I don't like having programs crash all the time (and i have not had a single program not crash yet).
I don't mind paying hundreds of dollars for a phone, but i want it to last for several years. I am so glad i didn't get the ipad yet. Apple will never get another dollar from me.
Really? So I'm assuming you have the 3G.
[rant]
Apple has done more to revolutionize the cell phone game than anyone else. Apple, while they don't do everything right, has caused the carriers to bend over backwards to accommodate the phone rather than the phone having to bend to the carrier's will. There have been a few compromises, but nothing like what we're seeing with Android handsets now having embedded game demos and other crap ware.
If you want to get rid of it fine, but don't say that your phone isn't lasting long enough. You didn't have to upgrade to iOS 4, and if you call Apple they will gladly fix it for you. I've been in my local Apple Store when someone came in after the iOS 3 update borked their phone. They simply swapped it out for another with the iOS 2 firmware.
So stop complaining here and just get them to fix it.
[/end rant]
That is ridiculous and completely unreasonable. Did you even read what you typed?? So this means we're now stuck on iOS2! Plug into iTunes and you're not prompted to upgrade to the latest 3.x... Only 4.
The problem I have is that I suspect Apple did this intentionally to push people to upgrade.
No, YOU ARE misreading mine. I said after they had done the v2 to v3 upgrade, not v3 to v4. I said, you don't have to upgrade.. no other phones offered system updates like this until the iPhone. The hardware is simply slow, so either keep it and be happy with v3 (by hacking it back, or calling Apple).. or get rid of the phone.. simple as that.
You aren't required to upgrade to v4, and it's been known for A LONG time that if you upgrade you are typically stuck with that firmware. They didn't have to give you v4 at all really.. they could've said that you're stuck with v3.. then everyone would be complaining about how Apple is "forcing" you to upgrade to get v4.
[rant]
[/end rant]
What do you mean i didn't have to upgrade it? I was getting the nag screen all the time while using the phone that i should upgrade. And that wasn't coming from itunes, but the phone itself while i was using it.
http://www.theatlantic.com/science/...s-experience-how-apple-stays-divine/60271/If
People like you are the definition of fanboys. You have this blind devotion to Apple, that they can do no harm. You come up with lies to support the product and build this worldview of Apple that doesn't exist. You just happen to be in an Apple store when a customer came in with a similar problem to ours, and you're telling me the Apple store swapped the customer phone with another phone? That is so BS. Apple wouldn't 'simply swap' it with another phone, the fact that you even say that shows how little you know about Apple.
