- Feb 14, 2004
- 48,654
- 5,419
- 136
Originally posted by: Tsaico
I would think so, and when you say kits, do you mean that you gather the needed parts and instructions, send them off to whoever bought it, and then they do the actual work? I think it is a cool idea.
And as for building your own cabinet, for the most part I would agree that the re-using an old dead cabinet is easy, but the couple of problems that I had were 1) the older cabinets were too narrow for comfort. I have pretty wide shoulders, and so do most of my friends, and I always hated playing Street Fighter II while also fighting for elbow room. If I made it custom, I could make it as wide as needed. 2) the costs of a good cabinet are usually about $200 with another $100 or so to get it to you, and the costs of the particle board was 4 $11 peices and about another $20 in 2x2 framing pieces, a single 2x2, and a single piece of 4x4. (I put a solid piece of 4x4 douglas in the bottom back and a handle on the top back portion, so I could put this thing on a dolly easily, since it is pretty heavy) Black deck screws are what is holding this thing together.
Also, I currently have some speed issues with my 1.4 pent 4 512 RAM rig. I can start games like Killer Instinct 1 and 2, but they run slower than the real deal, so I plan on replacing it with something a little faster CPU. How to the games work on the X-Box's CPU?
I thought about using something like that origionally, (since it is a little cheaper), but I decided to go with a standard PC so I could use the familiar PSU to power things like lights and the amp. I origionally put the flourescent light in the marquee with a seperate switch, but I didn't like that I had to first push power on the computer, then seperately turn on the lights. That was the same reason I did the CMOY amp too, I didn't want to turn a seperate speaker set on when powering up. It should do this on its's own.
Now if I could figure out how to open up the tv, so I could connect it's on/off button to the same butto that turns everything else on, that would be great.
All in all, probably about 80 bucks or so of lumber. But then again, if you don't have the right tools, and have to buy them for this project, I can see how that would easily increase the cost of making your cabinet five fold.
By "kit" I meant just the core Xbox system (modded console), not the cabinet or anything else. He does a lot of Xbox work and has a few spares that he can pre-mod to be ready for arcade use. Mine should be here next Saturday; it was originally going to be sooner but I'm having him add some LED buttons for the Power and Reset functions on the Xbox. That way I can reset the arcade or turn it on/off right from the cabinet instead of having to open the door and reach inside. Regarding gaming, I'll let you know after I get mine back. From what I've heard, everything runs great with the exception of the N64 and PSX emulators.
Building a cabinet looks like cake. Tablet saw + power drill and a few hours worth of work should render all the parts I need. I'd rather build my own than buy a pre-made one personally, since then I can customize it to my likings. I might be the only one in the world to have an arcade cabinet with built-in cupholders
As far as the TV goes, I'm skipping the glass/plastic front plate. The TV I have is old and requires you to go into the menu to switch over to AUX every time you turn it on. The universal remote I have for it doesn't activate the menu fuction, so I have to do it by hand. Remove monitor shield, problem solved!
