Just found out about these things not too long ago. I know they're popularly used for stripping paint, but what kind of jobs/applications I can use it for?
I've been looking at the Milwakuee ones. Should I get the high-end multi-variable temperature control one as an investment?
edit: I have a dent on the edge of my non-unibody MBP, - next to one of the USB ports. I'm thinking about using a heatgun to re-mold it the alu-housing. Possible? Or will I just screw-up the paint job?
The cheap ones are great for having one when you need it, if you are not going to use it much then go for the cheapest one you can find.
Professional ones are cool to have lying mostly in the closet though, it makes you way cooler than having a cheap one lying mostly in the closet.
For that job, i'd use a hammer and a larger (or smaller) bolt, you won't make the alu soft with ANY heat gun, you'll need a high capacity blow torch for that and even then it will disintegrate before it goes soft enough for you to form it.
