Originally posted by: Terranboy
I have a AthlonXP2600+, Nforce2, 512ram, R9800Pro. Praying that it will run good. I think I can get by on high.
Originally posted by: helpme
Playing it at 1280x1024 @ medium detail on a Dual 2800 MP (266 memory due to MPX chipset, so probably not as quick as most 2800 systems with 400 mhz memory)
The speed is not too bad, though it does get down to 15 fps or so at times. Average is probably around 30-35 fps.
Originally posted by: Mik3y
go 1024x768 at high quality...well, it depends on your cpu. as long as your system is running at xp3200+ or athlon 64 2800+, or pentium 3.0 GHz, then you can run at high quality. if your cpu is slower then that, you'll have to play at medium setting. note that there is currently do desktop pc where you can play the game at ultra quality smoothly. the game wont even run in my comp.
MIKEY, come on...
This is the 3rd or 4th post from you that is just NOT true..![]()
1600x1200 Ultra Settings..
1.4@2.4 AXP
1GB hyper X
6800 GT ( Ultra speeds )
MIKEY, come on...
1.4@2.4 AXP
1GB hyper X
i'm just stating wut the review for doom 3 systems were. i really dont know how well it can run on specific cpu's, but i'm just puttin down wut other guys in this forum mentiuned before.then again, u have a gt. try running it on an 9800 pro and tell me how it goes. it seems other people have the 9800 pro and a 2500+ or less and arent able to run the game very well according to their likes.
Originally posted by: tomstevens26
Running at 1024x768 high quality, with vsync enabled. PC is an AXP2500+ OC'ed to 2.2GHz and a 128MB 9800 Pro. Runs just fine for the most part. It occassionally freezes for just a split second when I enter a new area but other than that it's fine. Not sure if there is a way to get away from that freeze. Maybe taking it down to 800x600 will fix the problem but I'll have to try that later tonight when I get home.
Tom
Originally posted by: So
My 9600 pro is going to die a horrible horrible death when I load up doom 3
At tleast assuming that a 9600Pro is ~= to a 9600XT (and going by Anand's benches)
Ya, but you can still run @ leat 1024, medium qual.
Still a fun game..
