Anybody know how to get around a firewall? Update: Not having much luck.
C:\RC5\dnetc.ini
keyserver= ********
If you want to do some testing i have a zip file served up you can install that will set you up to my pproxy. That way we could see what you are doing and i already have the IP inserted.
ZIP file
this is for testing only and you can delete afterwards, not trying to recruit LOL 😉
😎 just LMK so I can be on the lookout. I am no networking expert either, so If that does not work you will have to wait for the experts to arrive 🙂 would hate to see all that power go to waste 🙁
I had a problem getting my machines to work through the firewall at my work. I ended up having to use the SOCKS5 protocol to get things working. Here is the relevant part of my ini file:
[networking]
firewall-type=socks5
firewall-host=192.168.0.1:1080
encoding=
firewall-auth=
autofindkeyserver=no
keyserver=proxy.teamanandtech.com
Since you can browse the internet on those computers, then you should definately be able to connect to dnet or one of the TA proxy servers. Can you go into your control panel|internet options and see how your browser is connected to the internet? You should just have to use the same settings in the Dnet software.
Edit: I use a the product "Wingate" proxy server.
Hi everyone, thanks for the help so far.
I'll be having another crack at it in about an hour and a quarter. So if any of of you could help around then it would be much appreciated.
See you soon. 🙂
I'm back! I'm in the room and ready to go.
So, first things first, I'll try cpars' idea. So, I'll unzip into c:/RC5 and go from there...
ok i will head downstairs and see if you connect to the proxy, ...should be fetching blocks first of all
Hmmm, this is what it says on the screen:
dnetc v2.8010-463-CTR-00071214 for Win32 (WindowsNT 5.0).
Please provide the *entire* version descriptor when submitting bug reports.
The distributed.net bug report pages are at http://www.distributed.net/bugs/
Using email address (distributed.net ID) 'rc5@tacube.com'
[Jun 21 02:39:27 UTC] Automatic processor detection found 1 processor.
[Jun 21 02:40:28 UTC] Connect to host 24.248.233.118:2064 failed.
Error 10060 (Attempt to connect timed out)
[Jun 21 02:40:28 UTC] Network:😱pen Error - sleeping for 3 seconds
[Jun 21 02:41:32 UTC] Connect to host 24.248.233.118:2064 failed.
[Jun 21 02:41:32 UTC] Network:😱pen Error - sleeping for 3 seconds
[Jun 21 02:41:35 UTC] Network::failed to resolve name "asia.v27.distributed ...
[Jun 21 02:41:35 UTC] Automatic processor type detection found
an Intel Pentium III processor.
[Jun 21 02:41:35 UTC] RC5: using core #2 (RG class 6).
[Jun 21 02:41:35 UTC] Loaded RC5 random 1*2^28 packet B2BC1C8E:40000000
[Jun 21 02:41:35 UTC] 0 RC5 packets (0 work units) remain in buff-in.rc5
[Jun 21 02:41:35 UTC] 0 RC5 packets (0 work units) are in buff-out.rc5
[Jun 21 02:41:35 UTC] 1 cruncher has been started.
.....10%.....20%.....30%.....40%.
[Jun 21 02:43:38 UTC] Connect to host 24.248.233.118:2064 failed.
[Jun 21 02:43:38 UTC] Network:😱pen Error - sleeping for 3 seconds
Well it seems like the client is actually reaching the outside world but there is something misaligned at the other end:
[Jun 21 02:54:38 UTC] Connect to host 24.248.233.118:2064 failed.
[Jun 21 02:54:38 UTC] Network:😱pen Error - sleeping for 3 seconds
[Jun 21 02:55:42 UTC] Connect to host 24.248.233.118:2064 failed.
[Jun 21 02:55:42 UTC] Network:😱pen Error - sleeping for 3 seconds
[Jun 21 02:55:45 UTC] Network::failed to resolve name "asia.v27.distributed ...
[Jun 21 02:55:45 UTC] Could not update to/from the net. Network down?
.....10%.....20%.....30%.....40%.....50%.....60%.....70%.....80%.....90%....100
[Jun 21 02:55:45 UTC] Completed RC5 packet B21E37BC:F0000000 (1*2^28 keys)
0.00:02:36.65 - [1,713,545.45 keys/sec]
yea i had shut down the PWS for a few minutes trying to get to my router setup, but i a unable to get in :| must be all of dant3R blocks in bobarding the router. for now all i can get open is port 2064 🙁
Well, without knowing the proxy that is being used, I can only help so much. It would appear that port 2064 is closed though. I monkeyed a bit with mine to see what the ini file would look like when changing around some of the settings.
Under the networking heading in the dnetc.ini file, try inserting the following:
[Networking]
keyserver=24.248.233.118:80
nettimeout=5
firewall-type=http
nofallback=true
Also, check your browser settings to see how you are connecting to the internet. For IE 5 and newer, it is under Tools-Internet Options, the click the connection tab and click the LAN settings button. That should give you the proxy settings. Let us know what they are, and we will try to give you the settings you need to have in your ini file.
If you get that one working and have full admin rights to all the machines, there is a program called "remote cows" that you can use to administrate/install all the rest of the machines, provided they are in the same domain/workgroup.
Hope some of this helps. 🙂
SD
Ok, I didn't realize the port wasn't open yet.. I will give you my pproxy address to test then.
[Networking]
keyserver=209.84.64.160:80
nettimeout=5
firewall-type=http
nofallback=true
Post and let me know if that works for you.
SD
Thanks guys. The smart IT bastards around here stopped us from accessing the LAN settings. I can't look at any settings on the entire computer! You can't even change the mouse speed :|
But I outsmarted them by writing the LAN settings down while they were still available half a year ago 😀. These numbers are from computers in another room but they should still be applicable to this room I suppose.
10.232.14.1
8080
That makes sense doesn't it?
just cut and paste what Slahr Dzhe posted into your C:\RC5\dnetc.ini and give his proxy a try, i need to see what the h*ll is up with my router.
Damn these PIII 667MHz comps are slow! Only 1.75 Mkeys/s
My Duron at 147 x 6 =882MHz goes at around 3Mkeys/s. Big difference considering little differnce in MHz. Ah well, the more the merrier.
WOOOOT!!!!!!!!
Ummm.. you need to get someone that has a non-revolving IP address on their proxy machine (like me) and use that for your proxy. I would suggest finding someone other than me to use, as my connection is going down for 3 weeks while they move my line from the old place to the new one.
Something else to try with the ini file.. see if you can put this line
keyserver=slahrdzhe.teamanandtech.com:80
where you have
If that works, post to let us know. 🙂
SD
That doesn't work:
[Jun 21 03:50:56 UTC] Network::failed to resolve name "slahrdzhe.teamanandt ...
[Jun 21 03:50:56 UTC] Could not update to/from the net. Network down?
