Any way to run 2 WoW apps at once?
KMFJD
33,710
54,158
Originally posted by: Aikouka
Originally posted by: KMFJD
1 run 4 instances of wow on my dual core system (2gb ram) with a 8800gt card, average fps is about 38 per instance...It works fine...
http://www.dual-boxing.com/
Same class? I find controlling 2 different classes at once can be a bit taxing at times :eek:.
I am trying a 1 Paladin/4 Hunter team at the moment, easiest to play by far is a priest/warlock group and an all shaman group is very popular at the moment.
lariz
83
Originally posted by: gizbug
ANswer is no.
Next question
Last question:
I have 1 WoW box installed (with BC). Would I have to buy a new box and install it along with buying a new account or can I just buy another account for $15 and play both from my first install?
Throckmorton
16,829
WTF? You play 4 WoW accounts at once? Something is wrong with you
TheVrolok
24,254
4,092
ANswer is no.
Next question
Last question:
Unless something has changed since I played (and it's possible) don't you still need a new copy of WoW and a new copy of BC for the new account?
BZeto
2,428
ANswer is no.
Next question
Last question:
You can play 2 accounts from the same WoW/BC install. As far as obtaining the 2nd account, you'd still need to buy another WoW retail and the expansion.
Dec 30, 2004
12,553
Just get MMOglider; I used that to take my 2nd warlock to 70 (undead; first was alli). If you are careful and create your own profiles and configure the program correctly and don't use other peoples' and don't afk glide, you'll be fine.
