Modelworks
Here is a quick list of the overall frequencies used on cable run in the home. All frequencies are in Mhz.
c-band 950-1750
Ku band 950-2150 (dish and directv)
Ka band - 950-1450
cable tv - 50 - 1050
VHF tv 50 - 200
UHF tv 470-890
FM 88-108
Cable modem return paths 20-48, 95-192
Cable modem downstream paths 650-1200
Moca 850-1550
You can see there is a lot of overlap on several of them . That doesn't mean they can't coexist , it just means you have to know what each is using in your home and make sure they don't try to use the same frequencies.
When using splitters you need to make sure they are designed for the frequencies you are using. Most splitters are going to peak at around 900Mhz. They will still work but the closer you get to the limit of their frequency the more damage to the signal. Ones sold for satellite use are a good purchase as they usually peak around 1.5-2Ghz.
Amplifiers should not be used unless you can't get the signal where it should be without it. A lot of people include them just in case and it does more harm than good. Also the cheap amplifiers will add more noise to the cable than they will improve the signal. Stick with name brands like blonder tongue, winegard for those.
If you use a splitter and have more ports than you need be sure to terminate the unused ones.
c-band 950-1750
Ka band - 950-1450
VHF tv 50 - 200
UHF tv 470-890
FM 88-108
Moca 850-1550
